    Ripped off SMA connector on Duet3 Mini5+
    • Tapetenhobelundefined
      Tapetenhobel
      in late December I bought the Duet3 mini 5+ (Filastruder order #65971) and used it for a month, but replaced it with an Duet2 Wifi and used Klipper on it. I was unhappy with the software quality ( intermittent skips, reported power failures in SBC mode and so on) but those seem to be finally resolved. When I mounted the board again and tried to connect the wifi antenna I discovered to my surprise that I ripped off the antenna socket. I poked the remaining bits out of the socket but was really on there.
      Tim asked me to open a thread for evaluation
      RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: QVSU6-Y196U-D65J0-40KML-NF03Z-7NHS0
      Used output buffers: 1 of 40 (14 max)
      Static ram: 98732
      Dynamic ram: 108128 of which 24 recycled
      Never used RAM 38332, free system stack 139 words
      Tasks: NETWORK(ready,449) HEAT(blocked,315) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,363) TMC(blocked,123) MAIN(running,438) IDLE(ready,20) AIN(blocked,269)
      Owned mutexes: USB(MAIN)
      Last reset 00:01:41 ago, cause: software
      Last software reset at 2021-02-20 17:39, reason: User, none spinning, available RAM 50628, slot 2
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
      Error status: 0x00
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      Supply voltage: min 0.9, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
      Cache data hit count 230190066
      Slowest loop: 99.89ms; fastest: 0.12ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.1ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.32ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      - WiFi -
      Network state is changingMode
      WiFi module is trying to connect
      WiFi firmware version 1.25
      WiFi MAC address f4:cf:a2:6f:bd:f7
      WiFi Vcc 3.42, reset reason Power up
      WiFi flash size 2097152, free heap 29824
      Clock register 00002002
      === CAN ===
      Messages queued 380, send timeouts 380, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
      WiFi reported error: Failed while trying to connect to FBI_Surveilance_Van
      WiFi module is idle
      WiFi reported error: no known networks found
      WiFi module is idle
      WiFi reported error: network scan failed
      Sapphire Pro, Mini 5+, BLTouch, PanelDue 3 5"
      Anycubic i3 Mega, SKR 1.4, Klipper
        Unfortunately we don't cover accidental damage under warranty. Occasionally we are able to offer refurb boards on exchange in non-warranty cases, but unfortunately we don't currently have any mini5+ boards available for that. That leaves repair as the only option and in this case the entire module would need to be replaced. Fortunately the modules themselves are not very expensive and replacing them isn't too difficult. If you're not comfortable replacing it yourself you might be able to find a local electronics shop or cell phone repair that could do it.
          dc42 administrators @Tapetenhobel
          The WiFi module is one of the easier components to replace, but removing it it does require either a hot air rework station, or extra low melting point solder such as ChipQuik, and then solder wick is needed to remove solder from the pads before fitting the new one.
          On the Duet 3 Mini5+ the WiFi module is a ESP-WROOM-02U. Either the 2Mbyte (16Mbit) or the 4Mbyte version will work. There is also an internal antenna version, ESP-WROOM-02D. They are available from the major electronic component suppliers, and I have seen them on eBay and Amazon too.
          There is a list of users who can do Duet repairs at https://forum.duet3d.com/topic/13875/community-repairs?_=1618864936096.
          Tapetenhobelundefined 1 Reply Last reply Reply Quote 0
            Tapetenhobel @dc42
            Thanks for the reply, I see that it's not covered by warranty to my stupidity, usually I'm pretty cautious. Anyway.
            Desoldering and putting a new one on it is not overly complicated since I soldered SMD components in my previous job, only BGA is challenging. I also have low temp soldering paste somewhere in my stash.
            Only question is: I currently have ESP8266-MOD modules (on some D1 mini). To my knowledge they are 4MB but I'm not sure about the pinout. Or I steal the ESP from my decommissioned Duet2 WIFI (MKS, never ever again).
              @tapetenhobel, the WROOM-02 module used on the Duet 3 Mini has a different pinout from the ESP-12S used on the Duet WiFi.
