Magnetic filament sensor Is there a way to disable mid-print?
    Steve Lynch
    I'm 97% into an almost 40 hour print of about 150 small parts on My 500 x 500 corexy. The filament sensor never allows a print to make it completely through without stopping at least 2 or 3 times. This particular print is using ironing (which I inadvertently sliced the file with) and each part is erroring 6-7 times before advancing to the next. I've literally been sitting here for 5 hours hitting resume, and I'm about to go batty!
    Is there a way to disable this thing so the print can finish on it's own?
    Also, I've worked on this thing for over a year, and I've never gotten it to survive an entire print. I've tried every suggestion you guys had.
    Before I simply put an open / close switch in, is there a way to set this so that it basically will be bulletproof, and only tell me when filament runs out? That's all I care about. Is there filament, or not?
    what settings would I need to change to ensure that I can finish a print without multiple interventions?
    Thanks so much!
    undefined 1 Reply Last reply 23 Apr 2021, 06:09 Reply Quote 0
      dc42 administrators @Steve Lynch
      @steve-lynch, send M591 D# S0 to disable the sensor, where # is the extruder number.
      undefined 1 Reply Last reply 23 Apr 2021, 09:47 Reply Quote 0
        Steve Lynch @dc42
        @dc42 Thanks man!
        undefined 1 Reply Last reply 23 Apr 2021, 09:55 Reply Quote 0
          droftarts administrators @Steve Lynch
          @steve-lynch Sorry if this is going over old ground, but what does your sensor currently report? Send M591 D# when it is running.
          Ironing, I think, extrudes tiny amounts of filament, so maybe there is some movement between the magnetic sensor and the extruder, so maybe these small movements are not being picked up?
          1 out of 4
