BLTouch Random firing pin
I have a Duet 3 with Duetpi. I am watching a print and the BLTouch occasionally releases and triggers back to standby. Sort of to the same thing as a start check.
Any clue as to why...checked the wires and code is good...the pin firing is random and seem to be tied to move or anything. -
Is it possible you have an intermittent break in the 5v supply cable that is causing a startup check?
Alternatively it could be interference being picked up and triggering a deploy? Can you move the bltouch cabling to separate it from other wiring?
