    Mesh Bed compensation "not working enough"
    • Tryptamineundefined
      Tryptamine
      Hey guys,
      I have quite an uneven printing surface (Maximum deviations: -0.368 / 0.520 mm)
      This is like 4 layer heights between highest and lowest point of the bed.
      I try to compensate for this with Mesh bed comp.
      I see the mesh bed comp working, the z axis are moving in the correct directions to counteract the uneven surface when moving XY.
      However, even with mesh bed comp on, the compensation is NOT ENOUGH to counteract the uneven surface.
      Printing a first layer test using all of the buildplate, i see the following:
      where i know the bed has a negative deviation, the layers do not stick. The needle hits the bed at the points of positive bed deviation.
      How can this be?
      Is my bed just too bad to be fully compensated for by mesh bed comp?
      Algorithm of what I did:
      Preheat to printing bed temp
      G29
      In config.g:
      G31 P500 X28 Y8 Z0.35                             ; set Z probe trigger value, offset and trigger height
      M557 X28:330 Y8:305 S40                            ; define mesh grid
      homeall.g:
      G1 H2 Z5 F18000         ; lift Z relative to current position
      G1 H1 X-350 Y-310 F6000 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-350             ; home X axis
      G1 H1 Y-310             ; home Y axis
      G1 X5 Y5 F18000         ; go back a few mm
      G1 H1 X-350 F300        ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-310             ; then move slowly to Y axis endstop
      G90                     ; absolute positioning
      G1 X-13 Y6 F18000       ; go to first bed probe point and home Z
      G30                     ; home Z by probing the bed
      start gcode:
      M561
      G28 ;Home
      G29 S1 P"heightmap.csv"
      G1 X350 Y20 F18000
      G1 Z0
      G1 X332 Y20 F18000
      G1 Z0.2
      G1 X330
      G1 X315 Z0.25 F120 E50
      ;G91
      ;G1 E-5 F1000
      ;G90
      G1 X330 Z0.2 F400
      G4 P3000
      G1 Z0.1 F9000
      G1 X300 Z0.35 F18000
      G1 X150 Y150 F18000
      ;G91
      ;G1 E5 F1000
      ;G90
      Anything wrong here?
      Any explanation?
      I could imagine the axis minima (0 for z) prevent the print head from following the printing surface because it'd have to move into negative z therefore. Otherwise, this is probably allowed in the firmware.
      Many thanks in advance!
      • wummelfroschundefined
        wummelfrosch
        Hy,
        what Kind of Z-Probe do you use ?
        1.Modified Prusa Style Printer:Duet2 Eth, 24V MW 750W, E3D Chimera+ Dual Wakü, 2x Bondt QR 500mm Bowden, 2x FTS 2.0 Sensor, BLTouch , 15mm CTC Linear Rails Y-Axis, 2xKGT-12x4 Z-Axis,10mm Linear X-Axis, Laing DDC Pump,120mm Radiator 2.Bcn3d Sigma R19
          Mesh compensation will allow going below the z0 point based on the heightmap, that's not a problem.
          You should home Z with the probe at the center of the bed. It looks like you're currently homing at a corner?
          Post your full config.g and the results of M122 please.
