    I2C on expansion board Duet3HC
    Firmware developers
    985
      dc42 administrators @o_lampe
      @o_lampe said in I2C on expansion board Duet3HC:
      @dc42 said in I2C on expansion board Duet3HC:
      The EXP3HC already provides an SPI connector.
      Sorry to bomb in here. David, is there a public access to SPI, like 'm260' is provided for I2C?
      I only found predefined sensors or NeoPixel stuff...
      You would need to change the firmware to support a new SPI device. However, something similar to M260 would be possible to add to the firmware.
      • Nikhilundefined
        Nikhil @dc42
        @dc42 I went through the datasheet again it does have I2C support on pin 16 & 17 on port A and it is in use by IO_0. So, I've already checked with the beta version and trying to use that. Hardware changes will do once after successful intialisation.
        As the sensor I'm using has only I2C support checked for alternative cannot find. So, will have to use the same may be I'll isolate the sensor wires.
        Que. As SAME51 uses 3 interrupt lines so, the 2 of them will be used for transmission and reception that was I thinking. Is it correct. I was going to use direct code by changing sercom number and handler but may be that will not going to work.
          dc42 administrators @Nikhil
          @nikhil I suggest you use the code already written, because it is known to work on the SAMC21. You will need to #define SUPPORT_I2C_SENSORS as 1 in file EXP3CH.h. Setting that should enable the code in Platform.cpp that creates an instance of SharedI2CMaster. Then you will need to create an instance of SharedI2CClient attached to that master for your sensor. Look at the CommandProcessing/AccelerometerHandler files to get an idea of how to use SharedI2CClient.
          Nikhilundefined 1 Reply Last reply Reply Quote 0
          • Nikhilundefined
            Nikhil @dc42
            @dc42 Hi, as you suggested I've made changes in firmware code
            #if SUPPORT_I2C_SENSORS
            	{ TcOutput::none,	TccOutput::none,	AdcInput::none,		SercomIo::none,		SercomIo::none,		Nx,	nullptr 		},	// PA16 		I2C SDA
            	{ TcOutput::none,	TccOutput::none,	AdcInput::none,		SercomIo::none,		SercomIo::none,		Nx,	nullptr			},  // PA17 	    I2C SCL
            #else
            	{ TcOutput::none,	TccOutput::none,	AdcInput::none,		SercomIo::none,		SercomIo::sercom1c,	Nx,	"io0.out,uart0.tx" },	// PA16
            	{ TcOutput::none,	TccOutput::none,	AdcInput::none,		SercomIo::sercom1c,	SercomIo::none,		Nx,	"uart0.rx"		},		// PA17
            #endif
            constexpr uint8_t I2CSercomNumber = 4;		//defined I2C serial comm number
            constexpr Pin I2CSDAPin = PortAPin(16);		//use 16 SDA
            constexpr GpioPinFunction I2CSDAPinPeriphMode = GpioPinFunction::C;
            constexpr Pin I2CSCLPin = PortAPin(17);		// use 17 SCL
            constexpr GpioPinFunction I2CSCLPinPeriphMode = GpioPinFunction::C;
            #define I2C_HANDLER4		SERCOM4_0_Handler    // changed the handler as it was calling dummy handler and going forever loop
            And also made changes in respect module file just like CommandProcessing/AccelerometerHandler
            #  ifndef I2C_HANDLER4    // added this statement as !defined() macro was showing error even after changing handler name.
            #	error "I2C_HANDLER4"
            #  endif
            	void I2C_HANDLER4() noexcept
            		Platform::sharedI2C->Interrupt();
            	}										// we may need to use 2 handlers for I2C
            # endif
            created task using
            monitorTask->Create(MonitorTaskCode, "sensor", nullptr, TaskPriority::Monitor);
            the sensor task is showing in diagnostics M122 B1 task list but the I2C task it's diagnostics not showing, I've checked all the Init registers with datasheet those are all same as SAMC21, How can I debug the I2C other than diagnostics, tried to send data on mainboard using CAN but no success. I've also tried to check if it's generating clock on SCL line using Oscilloscope no success.
              @nikhil There is no I2C task, and you don't need one.
              What code does your monitor task execute?
              You didn't need to add I2C_HANDLER4. Instead you should #define I2C_HANDLER0, 1, 2 in the config file.
              • Nikhilundefined
                Nikhil @dc42
                @dc42 okay will define these micros.
                monitor task for now just sending a command and receiving the data
                for (;;)
                		TaskBase::Take();
                		if (running)
                			CanMessageBuffer buf(nullptr);
                			//	CanMessageAccelerometerData& msg = *(buf.SetupStatusMessage<CanMessageAccelerometerData>(CanInterface::GetCanAddress(), CanInterface::GetCurrentMasterAddress()));
                			CanMonitorDataStart &monitorData = *(buf.SetupStatusMessage<
                					CanMonitorDataStart>(CanInterface::GetCanAddress(),
                #if TEST_PACKING
                			uint16_t pattern = 0;
                #endif
                			/*if (accelerometer->StartCollecting(axes))
                			if (monitor->readRangeSingleMillimeters() != 0)
                				data = monitor->readRangeSingleMillimeters();
                				monitorData.deviceNumber = 1;
                				if (monitor->timeoutOccurred())
                					debugPrintf("Timeout Error in monitor");
                			monitor->stopContinuous();		//stop sensor data*/
                			// Wait for another command
                			running = false;
                uint8_t readReg(uint8_t reg)
                  uint8_t value;
                  last_status = 0;
                  //bus->requestFrom(address, (uint8_t)1);
                 // value = bus->read();
                  return Transfer((uint8_t)reg, &value, 1, 1, VL53L0XI2CTimeout);
                uint16_t readRangeSingleMillimeters()
                  startTimeout();
                  while ((readReg(RESULT_INTERRUPT_STATUS) & 0x07) == 0)
                    if (checkTimeoutExpired())
                      did_timeout = true;
                      return 65535;
                  // assumptions: Linearity Corrective Gain is 1000 (default);
                  // fractional ranging is not enabled
                  uint16_t range = readReg16Bit(RESULT_RANGE_STATUS + 10);
                  writeReg(SYSTEM_INTERRUPT_CLEAR, 0x01);
                  return range;
                  @nikhil how do you set 'running' to true?
                  • Nikhilundefined
                    Nikhil @dc42
                    Init :--
                    Sensor *temp = new sensor(Platform::GetSharedI2C(), sensorxAddressLsb);  // added false for default addressss
                    	if (temp == nullptr)
                    		//	debugPrintf("error creating sensor"); no use
                    	if (temp->CheckPresent())   // returns hardcoded true As I was not having anything to check
                    		if (!temp->init())			/
                    		{					// waiting time should be less while initializing
                    			debugPrintf("not initializing the sensor\n");     //no use
                    			return;
                    			// increase timing budget
                    		temp->setMeasurementTimingBudget(200000);
                    		monitor = temp;
                    		monitorTask = new Task<MonitorTaskStackWords>;
                    	else
                    		delete temp;
                    Diagnostocs
                    # if SAME5x
                    		Platform::GetSharedI2C().Diagnostics(reply);
                    # endif
                    In Command processing
                    Sending temperary Gcode M54 to make 'running = true'
                    		case CanMessageType::monitorData:
                    			requestId = buf->msg.monitorData.requestId;
                    			rslt = MonitorHandlerProcessing::ProcessStartRequest(replyRef);
                    			break;
                    #endif
                    GCodeResult MonitorHandlerProcessing::ProcessStartRequest(const StringRef &reply) noexcept
                       reply.printf("Inside monitor");
                       if (monitor == nullptr)
                       	reply.printf("monitor %u not present", CanInterface::GetCanAddress());
                       	return GCodeResult::error;
                       if (running)
                       	reply.printf("Monitor is busy collecting data");
                       running = true;
                       monitorTask->Give();
                       return GCodeResult::ok;
                    first I use M54 B1 to start set 'running' = true and as soon as I do M122 B1 the response is given below and it stops the CAN communication. Means there's issue in implementing I2C client? is it?
                    M122 B1
                    Diagnostics for board 1:
                    Duet EXP3HC firmware version 3.3beta2+1PB1 (2021-04-28 17:18:32)
                    Bootloader ID: SAME5x bootloader version 2.3 (2021-01-26b1)
                    Never used RAM 158396, free system stack 0 words
                    Tasks: Move(notifyWait,160) HEAT(delaying,91) CanAsync(notifyWait,72) CanRecv(notifyWait,84) CanClock(notifyWait,74) Sensor(notifyWait,57) TMC(notifyWait,64) MAIN(running,438) AIN(delaying,260)
                    Last reset 00:03:58 ago, cause: reset button
                    Last software reset data not available
                    Driver 0: position 0, 80.0 steps/mm,  standstill, reads 41196, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
                    Driver 1: position 0, 80.0 steps/mm,  standstill, reads 41198, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
                    Driver 2: position 0, 80.0 steps/mm,  standstill, reads 41202, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
                    Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                    Peak sync jitter 10, peak Rx sync delay 188, resyncs 1, no step interrupt scheduled
                    VIN: 17.2V, V12: 12.3V
                    MCU temperature: min 39.0C, current 39.2C, max 39.4C
                    Ticks since heat task active 77, ADC conversions started 238550, completed 238549, timed out 0, errs 0
                    Last sensors broadcast 0x00000000 found 0 82 ticks ago, loop time 0
                    CAN messages queued 25, send timeouts 0, received 1167, lost 0, free buffers 36, min 36, error reg 0
                    dup 0, oos 0, bm 0, wbm 0
                    Error: M122: Response timeout: CAN addr 1, req type 6024, RID=52
                    ok
                      @nikhil have you defined all 3 of the I2C handlers? If not then the transmit interrupt will get stuck in the dummy handler.
                      • Nikhilundefined
                        Nikhil @dc42
                        @dc42 Yes I've defined all 3 handlers but the function calling inside handler is same. The interrupt function.
                        in config.h
                        #define I2C_HANDLER0		SERCOM4_0_Handler		// Handler for Interrupts all the handlers
                        #define I2C_HANDLER1		SERCOM4_1_Handler
                        #define I2C_HANDLER3		SERCOM4_2_Handler
                        in Platform.c
                        	void I2C_HANDLER0() noexcept
                        	void I2C_HANDLER1() noexcept
                        	void I2C_HANDLER3() noexcept
                        M122 B1
                        Duet EXP3HC firmware version 3.3beta2+1PB2 (2021-04-28 18:44:42)
                        Tasks: Move(notifyWait,160) HEAT(delaying,99) CanAsync(notifyWait,72) CanRecv(notifyWait,84) CanClock(notifyWait,74) VL53L0X(notifyWait,57) TMC(notifyWait,64) MAIN(running,442) AIN(delaying,260)
                        Last reset 00:00:28 ago, cause: software
                        Driver 0: position 0, 80.0 steps/mm,  standstill, reads 17991, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
                        Driver 1: position 0, 80.0 steps/mm,  standstill, reads 17994, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
                        Driver 2: position 0, 80.0 steps/mm,  standstill, reads 17998, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
                        Peak sync jitter 7, peak Rx sync delay 183, resyncs 1, no step interrupt scheduled
                        MCU temperature: min 39.2C, current 39.2C, max 39.2C
                        Ticks since heat task active 239, ADC conversions started 28984, completed 28984, timed out 0, errs 0
                        Last sensors broadcast 0x00000000 found 0 244 ticks ago, loop time 0
                        CAN messages queued 25, send timeouts 0, received 119, lost 0, free buffers 36, min 36, error reg 0
                        Monitor is available
                        ok
                        I2C section is not printing.
                          @nikhil, it's hard for me to comment further without seeing all the code.
                          • Nikhilundefined
                            Nikhil @dc42
                            @dc42 Thanks for the help. May be sensors function has problem will check those. Will add remote M260 for 3HC V1.0 with changes and contribute in 3HC's firmware.
                            I've bypassed the resistor R22. To get PA17 is it correct one.
                            • Nikhilundefined
                              Nikhil @Nikhil
                              Hi @dc42 , I went through the code and made changes. the module is working as I can see
                              I2C bus errors 0, naks 69, other errors 0
                              I2C device address 0x29
                              facing no acknowledgment. I'm using 0x29 address for the slave (sensor Adafruit VL53L0X) the same address I tried with arduino that's working fine. Can it be because of hardware. Or while sending data fast voltage is not reaching 3.3v or more?
                                @nikhil I suspect it is a firmware issue. Have you published your fork on github? Did you add external 4K7 pullup resistors to +3.3V, or does your I2C device already have those?
                                • Nikhilundefined
                                  Nikhil @dc42
                                  @dc42 It's working I changed the resistor as you said. I'll publish the fork. It was firmware issue.
                                  ardundefined 1 Reply Last reply Reply Quote 0
                                  • ardundefined
                                    ard @Nikhil
                                    @nikhil
                                    I'm struggle with similar problem to connect i2c sensor to expansion board Duet3HC.
                                    Could you publish your fork on github?
                                    Thanks in advance
