    I2C on expansion board Duet3HC
    Firmware developers
    985
    • Nikhilundefined
      Nikhil @dc42
      @dc42 okay will define these micros.
      monitor task for now just sending a command and receiving the data
      for (;;)
      		TaskBase::Take();
      		if (running)
      			CanMessageBuffer buf(nullptr);
      			//	CanMessageAccelerometerData& msg = *(buf.SetupStatusMessage<CanMessageAccelerometerData>(CanInterface::GetCanAddress(), CanInterface::GetCurrentMasterAddress()));
      			CanMonitorDataStart &monitorData = *(buf.SetupStatusMessage<
      					CanMonitorDataStart>(CanInterface::GetCanAddress(),
      #if TEST_PACKING
      			uint16_t pattern = 0;
      #endif
      			/*if (accelerometer->StartCollecting(axes))
      			if (monitor->readRangeSingleMillimeters() != 0)
      				data = monitor->readRangeSingleMillimeters();
      				monitorData.deviceNumber = 1;
      				if (monitor->timeoutOccurred())
      					debugPrintf("Timeout Error in monitor");
      			monitor->stopContinuous();		//stop sensor data*/
      			// Wait for another command
      			running = false;
      uint8_t readReg(uint8_t reg)
        uint8_t value;
        last_status = 0;
        //bus->requestFrom(address, (uint8_t)1);
       // value = bus->read();
        return Transfer((uint8_t)reg, &value, 1, 1, VL53L0XI2CTimeout);
      uint16_t readRangeSingleMillimeters()
        startTimeout();
        while ((readReg(RESULT_INTERRUPT_STATUS) & 0x07) == 0)
          if (checkTimeoutExpired())
            did_timeout = true;
            return 65535;
        // assumptions: Linearity Corrective Gain is 1000 (default);
        // fractional ranging is not enabled
        uint16_t range = readReg16Bit(RESULT_RANGE_STATUS + 10);
        writeReg(SYSTEM_INTERRUPT_CLEAR, 0x01);
        return range;
        @nikhil how do you set 'running' to true?
        Nikhilundefined 1 Reply Last reply Reply Quote 0
        • Nikhilundefined
          Nikhil @dc42
          Init :--
          Sensor *temp = new sensor(Platform::GetSharedI2C(), sensorxAddressLsb);  // added false for default addressss
          	if (temp == nullptr)
          		//	debugPrintf("error creating sensor"); no use
          	if (temp->CheckPresent())   // returns hardcoded true As I was not having anything to check
          		if (!temp->init())			/
          		{					// waiting time should be less while initializing
          			debugPrintf("not initializing the sensor\n");     //no use
          			return;
          			// increase timing budget
          		temp->setMeasurementTimingBudget(200000);
          		monitor = temp;
          		monitorTask = new Task<MonitorTaskStackWords>;
          		monitorTask->Create(MonitorTaskCode, "sensor", nullptr, TaskPriority::Monitor);
          	else
          		delete temp;
          Diagnostocs
          # if SAME5x
          		Platform::GetSharedI2C().Diagnostics(reply);
          # endif
          In Command processing
          Sending temperary Gcode M54 to make 'running = true'
          #if SUPPORT_I2C_SENSORS
          		case CanMessageType::monitorData:
          			requestId = buf->msg.monitorData.requestId;
          			rslt = MonitorHandlerProcessing::ProcessStartRequest(replyRef);
          			break;
          #endif
          GCodeResult MonitorHandlerProcessing::ProcessStartRequest(const StringRef &reply) noexcept
             reply.printf("Inside monitor");
             if (monitor == nullptr)
             	reply.printf("monitor %u not present", CanInterface::GetCanAddress());
             	return GCodeResult::error;
             if (running)
             	reply.printf("Monitor is busy collecting data");
             running = true;
             monitorTask->Give();
             return GCodeResult::ok;
          first I use M54 B1 to start set 'running' = true and as soon as I do M122 B1 the response is given below and it stops the CAN communication. Means there's issue in implementing I2C client? is it?
          M122 B1
          Diagnostics for board 1:
          Duet EXP3HC firmware version 3.3beta2+1PB1 (2021-04-28 17:18:32)
          Bootloader ID: SAME5x bootloader version 2.3 (2021-01-26b1)
          Never used RAM 158396, free system stack 0 words
          Tasks: Move(notifyWait,160) HEAT(delaying,91) CanAsync(notifyWait,72) CanRecv(notifyWait,84) CanClock(notifyWait,74) Sensor(notifyWait,57) TMC(notifyWait,64) MAIN(running,438) AIN(delaying,260)
          Last reset 00:03:58 ago, cause: reset button
          Last software reset data not available
          Driver 0: position 0, 80.0 steps/mm,  standstill, reads 41196, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
          Driver 1: position 0, 80.0 steps/mm,  standstill, reads 41198, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
          Driver 2: position 0, 80.0 steps/mm,  standstill, reads 41202, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
          Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
          Peak sync jitter 10, peak Rx sync delay 188, resyncs 1, no step interrupt scheduled
          VIN: 17.2V, V12: 12.3V
          MCU temperature: min 39.0C, current 39.2C, max 39.4C
          Ticks since heat task active 77, ADC conversions started 238550, completed 238549, timed out 0, errs 0
          Last sensors broadcast 0x00000000 found 0 82 ticks ago, loop time 0
          CAN messages queued 25, send timeouts 0, received 1167, lost 0, free buffers 36, min 36, error reg 0
          dup 0, oos 0, bm 0, wbm 0
          Error: M122: Response timeout: CAN addr 1, req type 6024, RID=52
          ok
            dc42 administrators @Nikhil
            @nikhil have you defined all 3 of the I2C handlers? If not then the transmit interrupt will get stuck in the dummy handler.
            • Nikhilundefined
              Nikhil @dc42
              @dc42 Yes I've defined all 3 handlers but the function calling inside handler is same. The interrupt function.
              in config.h
              #define I2C_HANDLER0		SERCOM4_0_Handler		// Handler for Interrupts all the handlers
              #define I2C_HANDLER1		SERCOM4_1_Handler
              #define I2C_HANDLER3		SERCOM4_2_Handler
              in Platform.c
              	void I2C_HANDLER0() noexcept
              		Platform::sharedI2C->Interrupt();
              	void I2C_HANDLER1() noexcept
              	void I2C_HANDLER3() noexcept
              M122 B1
              Duet EXP3HC firmware version 3.3beta2+1PB2 (2021-04-28 18:44:42)
              Tasks: Move(notifyWait,160) HEAT(delaying,99) CanAsync(notifyWait,72) CanRecv(notifyWait,84) CanClock(notifyWait,74) VL53L0X(notifyWait,57) TMC(notifyWait,64) MAIN(running,442) AIN(delaying,260)
              Last reset 00:00:28 ago, cause: software
              Driver 0: position 0, 80.0 steps/mm,  standstill, reads 17991, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
              Driver 1: position 0, 80.0 steps/mm,  standstill, reads 17994, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
              Driver 2: position 0, 80.0 steps/mm,  standstill, reads 17998, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
              Peak sync jitter 7, peak Rx sync delay 183, resyncs 1, no step interrupt scheduled
              MCU temperature: min 39.2C, current 39.2C, max 39.2C
              Ticks since heat task active 239, ADC conversions started 28984, completed 28984, timed out 0, errs 0
              Last sensors broadcast 0x00000000 found 0 244 ticks ago, loop time 0
              CAN messages queued 25, send timeouts 0, received 119, lost 0, free buffers 36, min 36, error reg 0
              Monitor is available
              ok
              I2C section is not printing.
                @nikhil, it's hard for me to comment further without seeing all the code.
                • Nikhilundefined
                  Nikhil @dc42
                  @dc42 Thanks for the help. May be sensors function has problem will check those. Will add remote M260 for 3HC V1.0 with changes and contribute in 3HC's firmware.
                  I've bypassed the resistor R22. To get PA17 is it correct one.
                  • Nikhilundefined
                    Nikhil @Nikhil
                    Hi @dc42 , I went through the code and made changes. the module is working as I can see
                    I2C bus errors 0, naks 69, other errors 0
                    I2C device address 0x29
                    facing no acknowledgment. I'm using 0x29 address for the slave (sensor Adafruit VL53L0X) the same address I tried with arduino that's working fine. Can it be because of hardware. Or while sending data fast voltage is not reaching 3.3v or more?
                      @nikhil I suspect it is a firmware issue. Have you published your fork on github? Did you add external 4K7 pullup resistors to +3.3V, or does your I2C device already have those?
                      • Nikhilundefined
                        Nikhil @dc42
                        @dc42 It's working I changed the resistor as you said. I'll publish the fork. It was firmware issue.
                        ardundefined 1 Reply Last reply Reply Quote 0
                        • ardundefined
                          ard @Nikhil
                          @nikhil
                          I'm struggle with similar problem to connect i2c sensor to expansion board Duet3HC.
                          Could you publish your fork on github?
                          Thanks in advance
