    Trigger on/off toggle
    Gcode meta commands
    • cosmowaveundefined
      cosmowave
      in my config.g i have defined a trigger with:
      M950 J0 C"!^E0STOP"									; Input 1 uses e1Stop pin, inverted, pullup enabled (FlowSensor)
      M581 P0 T2 S0 R0									; invoke trigger 2 when an active-to-inactive edge is detected on input 1, anytime
      I'd like to have a macro on the touchscreen for enable/disable the trigger with toggeling behavior.
      Is it possible to temporarly enable/disable the trigger? I think, it should be possible to do it with a variable. But eventually, there is another easy command to read the actual state of the trigger and set the trigger to active/inactive?
      Thanks for your help
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
      PaulHewundefined 1 Reply Last reply Reply Quote 0
      • PaulHewundefined
        PaulHew @cosmowave
        @cosmowave Have you seen this, it might help with what you are trying to achieve
        here
        REgards
        Paul
        cosmowaveundefined 1 Reply Last reply Reply Quote 0
          cosmowave @PaulHew
          @paulhew Thanks, but i have seen that.
          But i could not found the triggers in the OM!
