    Upgrading from Anet board with Auto leveling
    1.8k
    • wupinstickundefined
      wupinstick
      Hello everyone,
      I recently had my stock Anet A8 board die and thinking about upgrading to the Duet WiFi.
      My question is will my auto level sensor work with the Duet?
      Sensor - https://www.ia.omron.com/product/item/2202/
      more info on how it is wired up (plugs into stock z endstop connector) - https://www.thingiverse.com/thing:2241424
      below is some of the marlin config info i use for this switch
      [[language]]
      #define Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
      #define FIX_MOUNTED_PROBE
      #define X_PROBE_OFFSET_FROM_EXTRUDER 0   // X offset: -left  +right  [of the nozzle]
      #define Y_PROBE_OFFSET_FROM_EXTRUDER 53   // Y offset: -front +behind [the nozzle]
      #define Z_PROBE_OFFSET_FROM_EXTRUDER 0   // Z offset: -below +above  [the nozzle]
      // X and Y axis travel speed (mm/m) between probes
      #define XY_PROBE_SPEED 10000
      // Speed for the first approach when double-probing (with PROBE_DOUBLE_TOUCH)
      #define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z
      // Speed for the "accurate" probe of each point
      #define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2)
      // Use double touch for probing
      #define PROBE_DOUBLE_TOUCH
      #define Z_CLEARANCE_DEPLOY_PROBE   10 // Z Clearance for Deploy/Stow
      #define Z_CLEARANCE_BETWEEN_PROBES  5 // Z Clearance between probe points
      / For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
      // :{ 0:'Low', 1:'High' }
      #define X_ENABLE_ON 0
      #define Y_ENABLE_ON 0
      #define Z_ENABLE_ON 0
      #define E_ENABLE_ON 0 // For all extruders
      // Disables axis stepper immediately when it's not being used.
      // WARNING: When motors turn off there is a chance of losing position accuracy!
      #define DISABLE_X false
      #define DISABLE_Y false
      #define DISABLE_Z false
        Yes, you can use that, but you will have to feed it 5V from the expansion connector because the endstop connector only provides 3.3V.
          wupinstick
          So could I use the 5v from the panel connector?
          Then use the zprobe signal and ground pins?
          Or would I connect the probe to the z endstop connector like I have it on the Anet board?
          https://imgur.com/gallery/izfo9
          • number40fanundefined
            number40fan
            https://ibb.co/n7UAuv
            To the 5v on the right.
              wupinstick
              Where would I plug in my sensor? The E0 stop, z stop or zprobe?
              FYI I just ordered the duet wifi!!
                The outer 2 pins of the E0 endstop would be best.
                  wupinstick
                  Thanks! I'm sure I'll have more questions once my board arrives!
                    wupinstick
                    Ok so I just received my duet wifi!! I have setup the wifi and am able to access the web interface. I was going through the RepRapFirmware Configuration Tool and had some questions on translating my marlin settings.
                    I have provided links below that shows comparisons between marlin and the config tool.
                    http://imgur.com/XmuD66n config tool motor settings
                    http://imgur.com/mN9kzqM marlin motor settings
                    http://imgur.com/lA1gy2o config tool endstop settings
                    http://imgur.com/2wqDuZv marlin endstop settings
                    http://imgur.com/9gsdyXs marlin z probe settings
                      wupinstick
                      I think I have everything setup. the only thing I'm having issues with is the zprobe.
                      I have the zprobe wired up as dc42 suggested.
                      the gnd and signal pins from my sensor are wired to E0 endstop connections E0 stop and GND.
                      I have the 5v for my sensor connected to the 5V expansion connector pin 1.
                      when trying to run G29 I keep getting this error
                      Error: No valid grid defined for G29 bed probing
                      Below are some of my config settings for the z probe and my bed.g file
                      thanks for all of the help.
                      [[language]]
                      M111 S0                                         ; Debugging off
                      G21                                             ; Work in millimetres
                      G90                                             ; Send absolute coordinates...
                      M83                                             ; ...but relative extruder moves
                      M555 P2                                         ; Set firmware compatibility to look like Marlin
                      M208 X-14 Y0 Z0 S1                                 ; Set axis minimum set so x0 y0 is at corner of bed x=-14
                      M208 X220 Y220 Z240 S0                            ; Set axis maximum
                      ; ????????? not sure about zprobe configuration
                      M574 X1 Y1 Z0 S0                                 ; Define active low and unused microswitches
                      ;zprobe section ??????????
                      M558 P4 X0 Y0 Z1 H5 I1 F120 T6000                     ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
                      G31 X0 Y53 Z2                                     ; Set Z probe offset and trigger height see end of this file.
                      bed.g file
                      [[language]]
                      M561						;Clear any bed transform
                      G28							;Home all axes
                      M557 X10:210 Y53:210 S40 	;Define mesh grid
                      G29 S0						;Probe the bed and save height map to file
                      M374 						; Save calibration data. Default is sys/heightmap.csv
                        wupinstick
                        I think i found my problem. Let me know if I'm right.
                        When setting up the grid with M557 I should subtract the z probe y offset (53) from my current numbers.
                        I believe it should look like this: M557 X10:210 Y0:157 S40
                          You don't need to subtract the Z probe offset, however any points that are not reachable by the Z probe will not be probed.
                          My guess is that you had a typo in your M557 command.
                            wupinstick
                            Thanks for the help. I have everything working now!
                            just as a reference below are my zprobe and bed.g configs
                            Z-Probe
                            [[language]]
                            M558 P4 X0 Y0 Z1 H2 I1 F120 T6000
                            G31 P1000 X0 Y53 Z6.582
                            bed.g file
                            [[language]]
                            M561
                            G28
                            G90
                            M557 X10:210 Y0:210 S40
                            G29 S0
                            M374
                              You don't need the M374 command, the G29 S0 command will save to heightmap.csv anyway.
