RRF 3.2.2 problem with M291 S3 and cancel
Duet Web Control
589
    fcwilt @garyd9
    @garyd9
    If you include the M291 R parameter does it act differently?
      chrishamm administrators @garyd9
      @garyd9 I suppose RRF doesn't increment seqs.reply when M98 has started the new macro so DWC will resolve it once another command from the inputs has been processed. If you send M105 instead of M292 from the top G-code input, I bet you'll get the same result.
      This is one for @dc42. The message box dialog always sends M292 when OK is pressed and M292 P1 when Cancel is pressed.
      Duet software engineer
      undefined 1 Reply Last reply 31 Mar 2021, 08:17 Reply Quote 0
        dc42 administrators @chrishamm
        This is on my list to look at.
          garyd9
          For completeness, I wanted to add that running the above macro from PanelDue has no noticed irregularities regardless of if I press "OK" or "Cancel."
            resam
            I think I stumbled into the same problem from a different angle: https://forum.duet3d.com/topic/22516/sbc-dsf-api-with-m291-s3
            undefined 1 Reply Last reply 1 Apr 2021, 20:15 Reply Quote 0
              garyd9 @resam
              @resam said in RRF 3.2.2 problem with M291 S3 and cancel:
              In my case, using the example I posted in the OP, the code after the M291 does not execute until after 'OK' is pressed. Perhaps this is SBC/standalone difference?
                PaulHew
                I also am having an issue with M291 S3 Cancel and misses a line of code.
                Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.3beta3 (2021-04-22)
                Simple script to shutdown the Printer and Pi.
                M291 R"** SHUTDOWN **" P" Are you sure you want to SHUTDOWN the printer and Pi?" S3
                M106 P10 S0
                M7722
                Pops up on DWC and the PanelDue.
                If I press cancel, it clears the message on DWC not on the PanelDue, Spinning wheel next to macro, Misses the M106 command that turns off the Chamber lights and sends the M7722 anyway!
                Thought I was doing something wrong! (Not unusual for me 😉 )
                undefined 1 Reply Last reply 1 May 2021, 11:48 Reply Quote 0
                  chrishamm administrators @PaulHew
                  @paulhew I suppose you're using ExecOnMCode for that last number. If you are, please upgrade that plugin to the latest versions because there was a bug in it that could cause codes to be executed in the wrong order (it was missing a flush call).
                  undefined 1 Reply Last reply 1 May 2021, 12:51 Reply Quote 0
                    PaulHew @chrishamm
                    @chrishamm I do not know what ExecOnMCode is, I am afraid.
                    One part I missed, even if I hit cancel button it carries on and does not abort the macro.
                    The only plugins I have enabled are HeightMap and Object Model Browser.
                    Regards,
                    Paul.
                    undefined 1 Reply Last reply 1 May 2021, 12:59 Reply Quote 0
                      @paulhew Then how is M7722 interpreted, do you have a custom macro file for that?
                      undefined 1 Reply Last reply 1 May 2021, 14:01 Reply Quote 0
                        PaulHew @chrishamm
                        @chrishamm Sorry, Yes I do have ExecOnMCode.
                        I did not know the name... as it works and resides on the Pi.
                        I will look at upgrading it.
                        Regards,
                        undefined 1 Reply Last reply 1 May 2021, 16:02 Reply Quote 0
                          PaulHew @PaulHew
                          @paulhew So I updated to v5.2 for ExecOnMCode.
                          Cancel does not cancel the macro, it is as I pasted above. Still shutsdown.
                          Still misses the line which turns the lights off.
                          Not a show stopper, but might be for someone else.
                          Regards,
                          Paul.
                          undefined 1 Reply Last reply 30 Aug 2021, 20:16 Reply Quote 0
                            PaulHew @PaulHew
                            @paulhew
                            I still have this issue and I do not know how to fix it still.
                            I thought it was to do with Touchpanel firmware, but it happens in DWC also
                            Here are the details and the macro.
                            Duet Mini5 and 1LC - SBC mode. PanelDue 7i
                            m115
                            FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2021-06-15 21:46:20
                            This is my macro
                            M106 P10 S0
                            M7722
                            Still ignores the cancel 😞 and informs me Linux is disconnected.
                            Just tried it from DWC and clicked cancel it and it carries on and shuts down.
                            I think mine is either a firmware or DWC issue.
                            Hope someone can assist me and others that are struggling to cancel M291 commands.
                            Regards,
                            Paul.
