    Duet 3 32v on 3D printer?
    29
    1.8k
    • TypQxQundefined
      TypQxQ @dc42
      @dc42 said in Duet 3 32v on 3D printer?:
      Duet 3 has one 220uF capacitor per driver to help absorb this, plus an extra one on the 3HC.
      So does the 3HC handle voltage overshoots better with an extra capacitor or worse with only one capacitor?
      (English isn't my first language if it's obvious from the statement above)
        A Former User
        it is not the number of capacitors as such, but the combined value of them. removing one to add a bigger one is more work than just adding a bigger one, not to mention if its significantly larger it will not fit the pcb, ergo adding one to the screw terminals is easier and gets the job done.
        TypQxQundefined 1 Reply Last reply Reply Quote 0
        • TypQxQundefined
          TypQxQ @A Former User
          @bearer So the same formula can be used for the expansion but change from 6 steppers to 3? That gives
          sqrt(32.4*32.4 + 3 * (0.0044/0.00132) * 2 * 2) = 33.012V
          And same for 6 steppers:
          sqrt(32.4*32.4 + 6 * (0.0044/0.00132) * 2 * 2) = 33.612V
          So , am I right to draw the conclusion that it is marginally better to put 32.4v on a 3HC expansion than on a 6HC main board?
            A Former User
            @TypQxQ said in Duet 3 32v on 3D printer?:
            i think the 0.00132 value is the total capacitance for the main board. you'd need to calculate that for the expansion as it also has fewer capacitors. (but yes, i should expect it to be marginally better due to the additional cap, but not by much)
            and this is analouge stuff, I'm not known for practicing this dark art:)
              @bearer said in Duet 3 32v on 3D printer?:
              Correct.
              • TypQxQundefined
                TypQxQ @dc42
                @dc42 Does the firmware support diffrent voltage on Duet 3 6HC and connected 3HC expansion?
                  dc42 administrators @TypQxQ
                  Yes. And a different input voltage for OUT0 on the MB6HC too.
                  • TypQxQundefined
                    TypQxQ
                    Just an update.
                    It works great and my Meanwell LRS-350-36 can be turned down to 30V with the builtin regulator.
                    Now runing this on the 3HC expansion:
                    VIN: 30.9V, V12: 12.2V
                      A Former User
                      Interesting; i had to mod my SE-450 supply as it would only do 32.4 to 39.6V.
                      • gallaghersartundefined
                        gallaghersart
                        Per previous posts, hope I got correct.
                        6HC and 3HC can use different volts from each other. (in same system)
                        Mentions of hacking boards to get higher voltages means problems with 5v and 12v.
                        If my 3HC is only used for X and Y motors, could I modify my 3HC to use 36v or even 48v?
                        All sensors / fans / end stops etc.. would be from the 6HC.
                        Other option is 6HC + (1x) 1XD per axis along with “CNC style” separate drivers then motors.
                        Thanks!
                        `mike
                          dc42 administrators @gallaghersart
                          @gallaghersart said in Duet 3 32v on 3D printer?:
                          Yes, in principle. You would need to remove the diode that feeds fused VIN to the 12V and 5V regulators. Then feed 12 or 24V to the pad that the diode cathode was connected to, so that the onboard regulators can supply 12V to the drivers and 5V to the MCU etc.
                          The capacitors connected to the VIN supply to the drivers are rated at 50V. So 48V is too close, bearing in mind that when you turn the motors off they feed power back into the supply, causing an increase in supply voltage.
                            gallaghersart
                            Cool, thanks!
                            Still several weeks away from getting this printer up and running, will start with 24v to get all working.
                            Then I will test and share. Burn or Good should be fun.
                            Will investigate see how low I can adjust a 48v and then do the math.
                            `mike
                            • MortarArtundefined
                              MortarArt
                              So just to check that my working out is correct for this stepper with Inductance of 1.85 mH, using dc42's formula from above; sqrt(V^2 + n * (L/C) * I^2)
                              M906 current set at 4a
                              sqrt(3636 + 4(0.00185/0.00132) * 4 * 4) = 36.00000217066660122509v
                              I just want to be sure that this is right, because it seems that adjusting the amount of motors doesn't seem to change the result much?
