Solved 3.3-rc1 update reports as 3.3beta3 (2021-04-22)
3.3-rc1 update reports as 3.3beta3 (2021-04-22) under the machine specific tab of settings. On initial attempt to update, I got Duet2_SDiap32_WiFiEth.bin not found in firmware directory. I copied the file from the sys to the firmware directory, and the update appeared to work. Is this the wrong .bin file?
@adrian52 said in 3.3-rc1 update reports as 3.3beta3 (2021-04-22):
Your initial attempt to upgrade to 3.3RC1 probably failed because you had not uploaded the IAP file since you first upgraded to a 3.3beta version.
@dc42 thank you - fine now
