    [3.3-rc1] homing causes controller reset
    Beta Firmware
    • Serbitarundefined
      Serbitar
      Simple test at the moment using 3.3-rc1. Printer was working under 3.3b3.
      Power the controller and SBC up from the mains
      Try to home X by either hitting the home X button in DWC or typing G28 X into the DWC command sender.
      Board powers up but does not move any motors.
      I have this homex.g
      M98 P"/macros/poweron.g"
      M913 X30
      G91
      G1 H1 X-550 F20000 ; coarse home X
      G1 X20      F20000      ; move away from the endstops
      G1 H1 X-20 F1000   ; fine home X
      G90
      M913 X100
      G53 G1 X{-sensors.probes[0].offsets[0]} F20000
      m122
      RepRapFirmware for Duet 3 MB6HC version 3.3RC1 (2021-05-01 09:12:50) running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6J9D8-3S86J-9B36F
      Used output buffers: 1 of 40 (10 max)
      Static ram: 150680
      Dynamic ram: 62924 of which 0 recycled
      Never used RAM 140588, free system stack 208 words
      Tasks: SENSORS(delaying,0.0%,80) SBC(ready,5.7%,321) HEAT(delaying,0.0%,337) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,945) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.0%,343) TMC(notifyWait,0.0%,105) MAIN(running,93.9%,924) IDLE(ready,0.4%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:00:33 ago, cause: software
      Last software reset at 2021-05-01 18:10, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 140588, slot 2
      Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400804 BFAR 0x00000004 SP 0x2041af48 Task MAIN Freestk 1521 ok
      Stack: 2042b2b4 2042b334 2042b348 00000000 20424c20 00455f33 0044b182 81070000 00499e60 2042b434 00000000 00000000 00000000 20423f20 00000001 00000000 2041b0f0 ffffffed 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      Step timer max interval 736
      MCU temperature: min 42.9, current 43.0, max 43.3
      Supply voltage: min 0.2, current 0.2, max 0.3, under voltage events: 0, over voltage events: 0, power good: no
      12V rail voltage: min 0.1, current 0.1, max 0.2, under voltage events: 0
      Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
      Date/time: 2021-05-01 18:11:03
      Slowest loop: 1.10ms; fastest: 0.04ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Filament sensors ===
      Extruder 0 sensor: ok
      === CAN ===
      Messages queued 297, send timeouts 295, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49)
      Last cancelled message type 30 dest 127
      === SBC interface ===
      State: 1, failed transfers: 0
      Last transfer: 0ms ago
      RX/TX seq numbers: 3484/1190
      SPI underruns 0, overruns 0
      Number of disconnects: 0, IAP RAM available 0x2c90c
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.3-rc1
      Code buffer space: 4096
      Full transfers per second: 21.10
      Codes per second: 0.70
      Maximum length of RX/TX data transfers: 3444/932
      dcslog.txt
      config.g
      i@hevort:/opt/dsf/sd/sys $ cat config.g
      M550 P"hevort" ; set machine label
      M584 X0.3 Y0.4 Z0.0:0.1:0.2 E0.5 ; Assign drivers to axes
      M669 K1 ; Set system to CoreXY
      M569 P0 S0 D2 ;H0             ; Reverse Z1 motor direction
      M569 P1 S0 D2 ;H0             ; Reverse Z2 motor direction
      M569 P2 S0 D2 ;H0             ; Reverse Z3 motor direction
      M569 P3 S0 D2 ;H0             ; Reverse X motor direction
      M569 P4 S0 D2 ;H0             ; Reverse Y motor direction
      M569 P5 S0 D2 ;H0             ; Extruder motor setup, reverse direction
      M671 X-31:546:257 Y0:0:546 S100 ; Set Z probe points
      M574 X1 S1 P"io1.in"            ; Configure X endstop
      M574 Y1 S1 P"io2.in"            ; Configure Y endstop
      M574 Z2 S4                      ; Use stallguard for Z1 endstop for max Z. Allow each motor to stall independently
      M915 X S3 F0 R1                 ; Configure stallguard detection for X
      M915 Y S3 F0 R1                 ; Configure stallguard detection for Y
      M915 Z S1 H400 F1 R1            ; Configure stallguard detection for Z
      M915 E S3 F0 R1                 ; Configure stallguard detection for E
      M906 X1500 Y1500 Z1500 E1000 I80    ; Motor currents in ma + idle percentage
      M92 X80 Y80 E400 Z800               ; Steps per mm
      M203 Z2500 Y100000 X100000         ; Max feedrate in mm/min
      M201 X1000.0 Y1000.0 Z50.0 E250.0    ; Max acceleration mm/sec^2
      M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950 ; Set up bed thermistor
      M950 H0 C"out0" T0 Q10              ; Set up bed heater output
      M140 P0 H0                          ; Configure bed heater
      M307 H0 A110.3 C221.0 D3.9 V24.0 B0 ; Configure bed heating process parameters
      M304 P91.5 I3.111 D250.3            ; Configure bed heating PID parameters
      M308 S1 P"temp1" Y"thermistor" A"Hotend" T100000 ; B3950 ; Set up hotend thermistor
      M950 H1 C"out1" T1 ; Set up hotend heater
      M563 P0 S"Volcano" D0.5 H1 F2; Create new tool for hotend using air pump
      M143 H1 S300 A3 ; Set max heater temp to 300C
      G10 P0 X0 Y0 Z0 R0 S200 ; Set default tool temperatures and offsets
      ;M307 H1 A838.7 C467.3 D8.3 V23.9 B0 ; Hotend pid parameters
      ;M307 H1 R1.612 C384.3 D10.70 S1.00 V24.0 ; PID Parameters Volcano, 220C
      M307 H1 R1.752 C200.1 D8.36 S1.00 V24.0 ; PID Parameters Volcano, 220C + full berd air
      M308 S10 P"spi.cs0" Y"dht22" A"Enclosure Temp"          ; Set AM2302/DHT22 pin
      M308 S11 P"S10.1" Y"dhthumidity" A"Enclosure Humidity"  ; Set AM2302/DHT22 humidity subsensor
      M950 S2 C"io4.out"                 ; Bltouch servo pin
      M558 C"^io4.in" H20 F600 T6000 P9  ; Configure z probe, Bltouch
      M280 P2 S160                       ; Reset BLTouch
      G31 P500 X12 Y-27 Z2.733           ; set Z probe trigger value, offset and trigger height
      M950 C"out2" F0                    ; First fan = Water pump can add tacho input later
      M106 P0 S255 T50 C"Water pump" H1  ; Set Fan0 to be thermostatically controlled against hotend temp > 50C
      M950 C"out4+out4.tach"  F1         ; Second fan = radiator fan
      M106 P1 S255 T50 H1 C"Radiator fan"
      M950 C"out3"  F2 Q30000                ; Third fan = air pump
      M106 P2 C"Air pump"
      M950 C"out9"  F3 Q30000                ; Enclosure LED
      M106 P3 C"Lights" S255
      M950 C"!out5" F4                       ; HEVACS inverted PWM
      M106 P4 C"HEVACS"
      M591 D0 P1 C"^io0.in" S1               ; Filament runout sensor
      M208 X-265.7 Y-260 Z0 S1             ; Set axes minima
      M208 X249.3 Y245 Z470                ; Set axes maxima
      M557 X-250:249.3 Y-262.7:232 S25     ; Set probe grid limits
      M572 D0 S0.025                         ; Pressure advance
      M207 P0 S0.2 F2400                     ; Retraction 0.2mm at 40mm/s
      M98 P"/sys/config.g" returns no output.
      • tristanryerparkeundefined
        tristanryerparke
        @serbitar said in [3.3-rc1] homing causes controller reset:
        I'm getting the same issue.
        Does yours give this error after the connection is lost when trying to home?
        Lost connection to Duet (Board is not available (no header))
          dc42 administrators @tristanryerparke
          @Serbitar and @tristanryerparke, thanks for the report. I have located the problem and I am preparing a fix.
            dc42 administrators @Serbitar
            @serbitar and @tristanryerparke please try the new 3.3RC1+1 firmware binary at https://www.dropbox.com/sh/dlb58vkmu1u4fkx/AAAelkXSfRKVwI6_yqRnhGHPa?dl=0 and let us know whether it resolves the problem.
            Serbitarundefined tristanryerparkeundefined 2 Replies Last reply Reply Quote 0
            • Serbitarundefined
              Serbitar @dc42
              @dc42 That's fixed it!
              Thanks for turning the fix around so quickly 🙂
                tristanryerparke @dc42
                @dc42 You saved the day again david, back up and running no issues so far.
                Thanks,
                T
                • Nuramoriundefined
                  Nuramori
                  That fixed it for me as well.
