    Failed to Start Duet Control Server SBC
    Duet Web Control
    358
    • ivery86undefined
      ivery86
      Hello, i try to work with an Duet 3 and a Raspberry Pi 3b+ but im not able to connect to the DWC. I dont have any idea how to fix this problem.
      https://ibb.co/TcnC9Zp
      • PaulHewundefined
        PaulHew
        Are you using the supplied ribbon cable between the Duet and the Pi or have you made your own?
        • ivery86undefined
          ivery86
          Im using the supplied one. When i receive the Board its working fine, then i make a update over DWC ( zip file), now its not working. I Flash the pi some times (try Lite and normal) but its impossible to Start the Duet Control Server.
          I do all how its here explaned:
          https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
          • chrishammundefined
            chrishamm administrators @ivery86
            @ivery86 Did you flash RepRapFirmware 3.2.2 on the Duet controller via bossac? Can you ensure there is no SD card in the Duet?
            Duet software engineer
            • ivery86undefined
              ivery86
              The First Time i was updating over DWC. But i try severel times to Flash over Bossa. I try 3.1, 3.2, 3.3
              Yes without sd in the duet3
              • ivery86undefined
                ivery86
                Is it possible to Check the cable working Fine? Because When i Start without connected to the duet, its looking the same
                • ivery86undefined
                  ivery86
                  Now I have tried it from step one without duetpi the Problem is, im not able to Set the buffersize, i dont have the authorization
                    @ivery86 You do not need to set the buffer size if you are using DuetPi (or the supplied SD card in the Pi). I suggest you take a microUSB cable, connect the Duet to your PC, and send M122 to it.
                    If you are using DSF 3.2.2 as seen in your screenshot, you should be using RRF 3.2.2 as well. See here for further troubleshooting.
                    • ivery86undefined
                      ivery86
                      I checked it, its the 3.2.2 RRF. Now i order a new Ribbon cable, to Check if its the problem. Thank your for your help
                      • ivery86undefined
                        ivery86
                        Now i have checked the Resistence of the ribbon cable and its all ok. The First Time After i configurate the duet and the sbc (it worked) i plugged it wrong way and Powered it. is it possible something is damaged?
                        • ivery86undefined
                          ivery86
                          I bought a new RPI, now it works Fine
                            Phaedrux Moderator @ivery86
                            @ivery86 said in Failed to Start Duet Control Server SBC:
                            Interesting. Thanks for letting us know.
