Filament Sensor on Expansion with 3.3beta1 and 3.3beta3
Beta Firmware
filament sensor filament monitor expansion firmware
652
    vali3d
    I have issues with my filament sensors since the firmeware versions 3.3beta1
    The sensors are connected to expansion boards, together with the extruder motors.
    This setup did work on the firmeware 3.2, but since 3.3beta1 the input pins wont give back any signal (the filament sensor readout with M122 always says filament present). I have tried pluging a sensor and motor to the mainboard, which works fine. Other inputs like endstops in the expansions work fine.
    (all boards are 3.3beta3)
    Is this an known issue and will be fixed later on?
    greetings Valentin
      Can you provide your config.g and the results of M122 and M122 B1?
      undefined 1 Reply Last reply 3 May 2021, 14:31 Reply Quote 0
        vali3d @Phaedrux
        @phaedrux
        It looks like the individual board´s get it right. The sensor on 2.io2 should return no filament, the other three are loaded.
        3.5.2021, 16:26:06 M122 B2
        Diagnostics for board 2:
        Duet EXP3HC firmware version 3.3beta3 (2021-04-21 20:41:46)
        Bootloader ID: not available
        Never used RAM 158940, free system stack 0 words
        Tasks: Move(notifyWait,0.0%,160) HEAT(delaying,0.0%,88) CanAsync(notifyWait,0.0%,72) CanRecv(notifyWait,0.0%,83) CanClock(notifyWait,0.0%,74) TMC(notifyWait,22.8%,63) MAIN(running,75.9%,383) AIN(delaying,1.3%,263), total 100.0%
        Last reset 00:01:53 ago, cause: software
        Last software reset at 2021-04-30 13:19, reason: AssertionFailed, available RAM 158940, slot 0
        Software reset code 0x0120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00430000 BFAR 0xe000ed38 SP 0x2000378c Task MAIN Freestk 795 ok
        Stack: 00000544 0002eb3c 0002614f 42000400 00022387 20001c90 00000001 00000003 20001c8c 20001c7c 0001d30f 00000001 200037e0 00000001 000190a7 0001e49a 41000000 00000000 00026043 08020c02 00000001 00000000 11a80200 00000024 a300a5a5 20003c78 00000003
        Driver 0: position 0, 201.9 steps/mm, standstill, reads 51251, writes 13 timeouts 0, SG min/max 0/0, steps req 0 done 0
        Driver 1: position 0, 201.9 steps/mm, standstill, reads 51253, writes 13 timeouts 0, SG min/max 0/0, steps req 0 done 0
        Driver 2: position 0, 201.9 steps/mm, standstill, reads 51257, writes 13 timeouts 0, SG min/max 0/0, steps req 0 done 0
        Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
        Peak sync jitter 11, peak Rx sync delay 178, resyncs 0, no step interrupt scheduled
        VIN: 24.3V, V12: 12.1V
        MCU temperature: min 28.6C, current 29.6C, max 29.6C
        Ticks since heat task active 0, ADC conversions started 113346, completed 113346, timed out 0, errs 0
        Last sensors broadcast 0x00000000 found 0 5 ticks ago, loop time 0
        CAN messages queued 108, send timeouts 0, received 1496, lost 0, free buffers 36, min 36, error reg 0
        dup 0, oos 0, bm 0, wbm 0
        === Filament sensors ===
        Interrupt 5726621 to 0us, poll 1 to 80us
        Driver 0: ok
        Driver 1: no filament
        Driver 2: ok
        3.5.2021, 16:25:51 M122 B1
        Diagnostics for board 1:
        Never used RAM 158196, free system stack 0 words
        Tasks: Move(notifyWait,0.0%,160) HEAT(delaying,0.0%,88) CanAsync(notifyWait,0.0%,72) CanRecv(notifyWait,0.0%,83) CanClock(notifyWait,0.0%,74) TMC(notifyWait,23.5%,63) MAIN(running,75.0%,301) AIN(delaying,1.5%,263), total 100.0%
        Last reset 00:01:38 ago, cause: software
        Last software reset data not available
        Driver 0: position 0, 80.0 steps/mm, standstill, reads 50783, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
        Driver 1: position 0, 80.0 steps/mm, standstill, reads 50786, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
        Driver 2: position 0, 201.9 steps/mm, standstill, reads 50787, writes 13 timeouts 0, SG min/max 0/0, steps req 0 done 0
        Peak sync jitter 10, peak Rx sync delay 178, resyncs 0, no step interrupt scheduled
        VIN: 24.1V, V12: 12.1V
        MCU temperature: min 28.0C, current 29.1C, max 29.1C
        Ticks since heat task active 172, ADC conversions started 98468, completed 98468, timed out 0, errs 0
        Last sensors broadcast 0x00000018 found 2 176 ticks ago, loop time 0
        CAN messages queued 1275, send timeouts 0, received 916, lost 0, free buffers 36, min 36, error reg 0
        Interrupt 5726621 to 0us, poll 1 to 117us
        Driver 2: ok
        3.5.2021, 16:24:43 M122
        RepRapFirmware for Duet 3 MB6HC version 3.3beta3 (2021-04-22 16:28:03) running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
        Board ID: 08DJM-956L2-G43S4-6JTD8-3SS6J-9B7GH
        Used output buffers: 3 of 40 (19 max)
        Static ram: 149960
        Dynamic ram: 94824 of which 0 recycled
        Never used RAM 109408, free system stack 200 words
        Tasks: NETWORK(ready,27.8%,226) ETHERNET(notifyWait,0.1%,124) HEAT(delaying,0.0%,281) Move(notifyWait,0.0%,202) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.0%,350) TMC(notifyWait,7.6%,93) MAIN(running,64.0%,1114) IDLE(ready,0.4%,19), total 100.0%
        Owned mutexes:
        Last reset 00:00:30 ago, cause: software
        Last software reset at 2021-05-03 16:24, reason: User, GCodes spinning, available RAM 109416, slot 2
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        Aux1 errors 0,0,0
        Step timer max interval 128
        MCU temperature: min 36.2, current 36.9, max 36.9
        Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
        Driver 0: position 0, standstill, reads 36613, writes 14 timeouts 0, SG min/max 0/0
        Driver 1: position 0, standstill, reads 36614, writes 14 timeouts 0, SG min/max 0/0
        Driver 2: position 0, standstill, reads 36614, writes 14 timeouts 0, SG min/max 0/0
        Driver 3: position 0, standstill, reads 36614, writes 14 timeouts 0, SG min/max 0/0
        Driver 4: position 0, standstill, reads 36614, writes 14 timeouts 0, SG min/max 0/0
        Driver 5: position 0, standstill, reads 36614, writes 14 timeouts 0, SG min/max 0/0
        Date/time: 2021-05-03 16:24:42
        Slowest loop: 4.76ms; fastest: 0.05ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 3.0ms, write time 0.0ms, max retries 0
        DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        Extruder 0 sensor: no filament
        Extruder 1 sensor: no filament
        Extruder 2 sensor: no filament
        Extruder 3 sensor: no filament
        === CAN ===
        Messages queued 309, send timeouts 0, received 436, lost 0, longest wait 9ms for reply type 6018, peak Tx sync delay 6, free buffers 49 (min 48)
        === Network ===
        Slowest loop: 3.33ms; fastest: 0.02ms
        HTTP sessions: 1 of 8
        • Ethernet -
          State: active
          Error counts: 0 0 1 0 0
        config (2).g
          vali3d
          I did another test just now, and they worked. I have no Idea why, but the M122 is still saying no filament on all 4 extruders.
            Can you update to RC1 and see if it's the same? Maybe a display bug in M122 output.
            undefined 1 Reply Last reply 4 May 2021, 09:48 Reply Quote 0
              vali3d @Phaedrux
              @phaedrux
              4.5.2021, 11:46:52 M122 B2
              Duet EXP3HC firmware version 3.3RC1 (2021-04-29 10:20:51)
              Never used RAM 159212, free system stack 0 words
              Tasks: Move(notifyWait,0.0%,160) HEAT(delaying,0.0%,88) CanAsync(notifyWait,0.0%,72) CanRecv(notifyWait,0.0%,83) CanClock(notifyWait,0.0%,74) TMC(notifyWait,23.2%,63) MAIN(running,75.5%,389) IDLE(ready,0.0%,40) AIN(delaying,1.3%,263), total 100.0%
              Last reset 00:01:35 ago, cause: power up
              Last software reset at 2021-05-03 17:21, reason: AssertionFailed, available RAM 158940, slot 1
              Stack: 00000544 0002eb3c 0002614f 42000400 00022387 20001c90 00000001 00000003 20001c8c 20001c7c 0001d30f 00000001 200037e0 00000001 000190a7 3a36d584 41200000 00000000 00026043 20000010 00000001 00000000 11a80200 00000024 a300a5a5 20003c78 00000001
              Driver 0: position 0, 201.9 steps/mm, standstill, reads 27958, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
              Driver 1: position 0, 201.9 steps/mm, standstill, reads 27961, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
              Driver 2: position 0, 201.9 steps/mm, standstill, reads 27964, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
              Peak sync jitter 10, peak Rx sync delay 180, resyncs 0, no step interrupt scheduled
              MCU temperature: min 20.4C, current 24.6C, max 24.6C
              Ticks since heat task active 175, ADC conversions started 95944, completed 95944, timed out 0, errs 0
              Last sensors broadcast 0x00000000 found 0 180 ticks ago, loop time 0
              CAN messages queued 100, send timeouts 0, received 1270, lost 0, free buffers 36, min 36, error reg 0
              Driver 0: ok
              Driver 2: ok
              4.5.2021, 11:46:34 M122 B1
              Never used RAM 158468, free system stack 0 words
              Tasks: Move(notifyWait,0.0%,160) HEAT(delaying,0.0%,88) CanAsync(notifyWait,0.0%,72) CanRecv(notifyWait,0.0%,83) CanClock(notifyWait,0.0%,74) TMC(notifyWait,23.3%,63) MAIN(running,75.3%,301) IDLE(ready,0.0%,40) AIN(delaying,1.4%,263), total 100.0%
              Last reset 00:01:18 ago, cause: power up
              Driver 0: position 0, 80.0 steps/mm, standstill, reads 61770, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
              Driver 1: position 0, 80.0 steps/mm, standstill, reads 61773, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
              Driver 2: position 0, 201.9 steps/mm, standstill, reads 61771, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
              Peak sync jitter 9, peak Rx sync delay 177, resyncs 0, no step interrupt scheduled
              MCU temperature: min 19.9C, current 23.6C, max 23.6C
              Ticks since heat task active 10, ADC conversions started 78355, completed 78355, timed out 0, errs 0
              Last sensors broadcast 0x00000018 found 2 14 ticks ago, loop time 0
              CAN messages queued 1020, send timeouts 0, received 732, lost 0, free buffers 36, min 36, error reg 0
              Driver 2: ok
              4.5.2021, 11:46:29 M122
              RepRapFirmware for Duet 3 MB6HC version 3.3RC1 (2021-05-01 09:12:50) running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
              Used output buffers: 1 of 40 (19 max)
              Static ram: 150680
              Never used RAM 108688, free system stack 182 words
              Tasks: NETWORK(ready,27.6%,238) ETHERNET(notifyWait,0.1%,118) HEAT(delaying,0.0%,301) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.0%,350) TMC(notifyWait,7.3%,93) MAIN(running,64.7%,1114) IDLE(ready,0.2%,29), total 100.0%
              Owned mutexes:
              Last reset 00:01:13 ago, cause: power up
              Last software reset at 2021-05-03 18:17, reason: User, GCodes spinning, available RAM 108672, slot 1
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x00
              Aux0 errors 0,0,0
              Aux1 errors 0,0,0
              Step timer max interval 127
              MCU temperature: min 19.1, current 31.3, max 31.6
              Driver 0: position 0, standstill, reads 14259, writes 14 timeouts 0, SG min/max 0/0
              Driver 1: position 0, standstill, reads 14259, writes 14 timeouts 0, SG min/max 0/0
              Driver 2: position 0, standstill, reads 14259, writes 14 timeouts 0, SG min/max 0/0
              Driver 3: position 0, standstill, reads 14259, writes 14 timeouts 0, SG min/max 0/0
              Driver 4: position 0, standstill, reads 14260, writes 14 timeouts 0, SG min/max 0/0
              Driver 5: position 0, standstill, reads 14260, writes 14 timeouts 0, SG min/max 0/0
              Date/time: 2021-05-04 11:46:28
              Slowest loop: 4.80ms; fastest: 0.05ms
              === Storage ===
              SD card longest read time 3.1ms, write time 0.0ms, max retries 0
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              === CAN ===
              Messages queued 697, send timeouts 0, received 992, lost 0, longest wait 1ms for reply type 6018, peak Tx sync delay 4, free buffers 49 (min 48)
              === Network ===
              Slowest loop: 4.64ms; fastest: 0.02ms
              • Ethernet -
                State: active
              undefined 1 Reply Last reply 4 May 2021, 19:40 Reply Quote 0
                dc42 administrators @vali3d
                @vali3d do M591 D0, M591 D1, M591 D2 and M591 D3 return the correct status?
                What type of filament sensors are they? Please show us the M591 lines in config.g that you use to configure them.
                  vali3d
                  config (2).g
                  M591 D0 P1 C"1.io2.in" S1
                  M591 D1 P1 C"2.io1.in" S1
                  M591 D2 P1 C"2.io2.in" S1
                  M591 D3 P1 C"2.io3.in" S1
                  The sensors are simple switches (high signal when filament present).
                  Like I wirten, in the M122 B1/B2 the readout is correct.
                  Driver 0: ok
                  Driver 2: ok
                  Driver 2: ok
                  5.5.2021, 09:01:04 M591 D3
                  Simple filament sensor on pin 2.io3.in, enabled, output low when no filament, filament present: yes
                  5.5.2021, 09:00:59 M591 D2
                  Simple filament sensor on pin 2.io2.in, enabled, output low when no filament, filament present: no
                  5.5.2021, 09:00:56 M591 D1
                  Simple filament sensor on pin 2.io1.in, enabled, output low when no filament, filament present: yes
                  5.5.2021, 09:00:46 M591 D0
                  Simple filament sensor on pin 1.io2.in, enabled, output low when no filament, filament present: yes
                  undefined 1 Reply Last reply 5 May 2021, 09:39 Reply Quote 0
                    @vali3d thanks, so it's just the M122 main board filament monitor summary that is wrong. I'll log this as a known issue for fixing in a future release.
                    undefined 1 Reply Last reply 5 May 2021, 09:43 Reply Quote 0
                      vali3d @dc42
                      at my first try, the sensors didn´t work(3.3beta1/3). One day later, without any changes they did work(3.3beta3and 3.3RC1). Since then they do work and only the M122 readout is wrong(3.3RC1).
                      4 out of 10
