    PWM to constant DC voltage for fan control
    1.3k
    • bananapuppyundefined
      bananapuppy @Egon.Net
      @egon-net thanks for making these graphs, very useful to me! Does the voltage still overshoot to about 16V with 100% PWM, when using a 100nF capacitor?
      How about a capacitor somewhere between 100nF and 1ยตF? I.e. 0.47ยตF for instance, I figure that might be a nice middle ground for ripple with not too much of an overshoot ๐Ÿ˜„?
      Egon.Netundefined 1 Reply Last reply Reply Quote 0
      • Egon.Netundefined
        Egon.Net @bananapuppy
        @bananapuppy you are welcome ๐Ÿ™‚
        With a 100nF capacitor the overshoot should be about 1.5V (13.5V max for 12V), and ripple about 1Vpp
        The bigger the cap, the bigger the overshoot.
        dc42undefined bananapuppyundefined 2 Replies Last reply Reply Quote 0
          dc42 administrators @Egon.Net
          A ripple of 1V p-p is unlikely to matter.
          • Egon.Netundefined
            Egon.Net @dc42
            @dc42 said in PWM to constant DC voltage for fan control:
            I agree.
            Is there any drawback for the Duet with the highest PWM frequencies (CPU/resource usage wise) besides a tiny bit more power consumed by the mosfet?
              @egon-net @dc42 thanks! I recon the following should do for a capacitor then? A ceramic one, as electrolytic doesn't even seem available at 100nF, does that matter? There was mention of ESR with use of an electrolytic capacitor / being used in the simulation?
              SA105E104MARTB AVX
              • Egon.Netundefined
                @bananapuppy said in PWM to constant DC voltage for fan control:
                SA105E104MARTB AVX
                Ceramic is ok, but I'd try to get one with X5R or X7R dielectric. The one you picked has Z5U dielectric which is not that good.
                bananapuppyundefined 1 Reply Last reply Reply Quote 1
                  @egon-net no idea what that difference means (if someone can recommend me a good electronics course, please do ๐Ÿคฃ), but the following should be good then!? ๐Ÿ˜„
                  CM-100N-X7R SR PASSIVES
                    dc42 administrators @bananapuppy
                    CM-100N-X7R
                    Yes, that's 100nF 100V X7R.
                      @egon-net said in PWM to constant DC voltage for fan control:
                      I agree.
                      Just a little more heat dissipation in the mosfet, and perhaps slightly poorer resolution in the PWM setting.
                      • Egon.Netundefined
                        Egon.Net @dc42
                        @dc42 nice, thanks!
                        • droftartsundefined droftarts referenced this topic
