HELP! Duet 2 WiFi Configuration and DWC Upload???
@pcnoobneedsmajorhelp said in HELP! Duet 2 WiFi Configuration and DWC Upload???:
That coupled with the fact that my PanelDue says its extruding different values that my DWC is.
What do you mean by that?
After the 8th time measuring out my black line
Mark the line farther up so that it doesn't get sucked down past where you can measure.
So if you look at the two pictures above, one is of my computer screen showing my extrusion setting on the DWC and the other is a picture of my PanelDue with the extrusion settings pulled up, and they don't match.
Just realizing that I never sent the picture, my bad.
So, just ran the same test (with marking the line) and this time it was way short. short of the 100mm mark by 35mm.
they don't match.
That's correct. They don't match. The DWC values are also editable if you right click on the buttons. that's just the way it is.
Well it's going to take a few passes to get it dialed in.
33mm is the average. so do I increase the steps or lower them?
sorry, I'll just do the equation, duh carson. long day
you'll get there
Ok. we're good. 139 steps
I'll recheck everything once more and then run a test print.
Sorry if I was rude or sounded like I had an attitude at any point. When I get frustrated I tend to be short with people. There's no excuse for that kind of behavior.
Any thoughts on the PanelDue issue?
-I'll probably be in touch.
Thanks,
-Carson
It's not an issue. They just have different options. See my comments above.
No worries.
So I uploaded a calibration cube gcode to the DWC to find my flow rate percentage.
Once everything was heated up, it initiated by homing (very slowly) (my initial layer speed is at 20, but this was way slower). Then, usually it would extrude a straight line next to its home location before the print, then head to the center of the bed to start the skirt. But this time after the initial homing, it started to move diagonal to the opposite corner very very slow, and I thought it was going to crash so I Estopped it, then homed it and it homed back at normal speeds
Just wondered what you thought that could be?
Thanks,
-Carson
What slicer are you using?
What is in the start gcode section in the slicer? -
Cura 4.8.0
Should I match The Cura machine settings values to match my config.g settings values?
Just remove the M201, M203, M204, M205 lines from the start gcode.
Also switch your gcode flavor from Marlin to RepRap.
It's still doing it. I wasn't paying attention and thought it was going to crash but it didn't. It's just doing what it normally does with the line before the print but at the opposite corner. Is that just how it is now or can we change that.
-So its starting the print from the front left instead of the back right (where in want it to start from)
Thoughts?
Thanks,
-Carson
It's also not automatically heating the extruder to the Cura printing settings
Ignore that last reply. I guess the bed heats up first
Just finished the first print. At the end of the print it went to the wrong corner (opposite of home positions) and then X and Y crashed violently.
I don't see anything in your slicer end gcode that would move it like that at the end of the print. Can you share the gcode file itself?
-So its starting the print from the front left instead of the back right (where in want it to start from)We set it up as a left hand coordinate system to match what the slicer uses. I'm not sure why Creality chose a mirrored X and Y for the Ender5. It makes no sense.
If you really wanted to, it can be switched back, but requires changing the M574 endstop location and the homing directions.
