    Power Failure
    Firmware installation
    2.6k
      Did anything happen at all?
      • TYPPA Albert Einsteinundefined
        Yes I create this macro on SYS
        files sys/powerfail.g, sys/powerrestore.g and sys/resurrect-prologue.g
        copy the example for Delta …itwork fine the system but not run the resurrect.g for printing
        I have no special talent. I am only passionately curious.
        -Albert Einstein
          What I meant was: if you send M98 Presurrect.g, does anything happen at all? Do you get any messages in the Console window of DWC?
          Please post the contents of resurrect.g.
            on config,g
            ;Power Failure
            M911 S6.0:9.75:11.0 ; PSU 12V
            Editing 0:/sys/resurrect.g
            ; File "Test100.gcode" resume print after auto-pause at 2017-07-07 11:33
            M140 S40.0
            G10 S212 R0
            T0 P0
            G92 E6.965
            G29 S1
            M98 Presurrect-prologue.g
            M106 P0 S0.00
            M106 P1 S0.00
            M106 P2 S0.00
            M106 P3 S0.00
            M106 P4 S0.00
            M106 P5 S0.00
            M106 P6 S0.00
            M106 P7 S0.00
            M106 P8 S0.00
            M106 S0.00
            M116
            M290 S0.000
            M23 Test100.gcode
            M26 S6011
            G1 F6000 X-52.85 Y51.40 Z0.20
            G1 F1470.0 P0
            M24
            Send on DWC M98 Presurrect.g
            reponse from DWC
            15:47:25M98 PRESURRECT.G
            Macro file resurrect-prologue.g not found.
            on SYS Editing 0:/sys/resume-prologue.g
            M116
            G28
            M83
            G1 E2 F3600
            NOT the file resurrect-prologue.g ?
            -Albert Einstein
              I'm sorry, you need to rename resume-prologue.g to resurrect-prologue.g. I changed the filename during development, and when I updated that wiki page I updated all occurrences of that filename… except one. I've corrected it now.
                Ok i test now ….thaks David
                i post after the result
                -Albert Einstein
                  There is a bug in the resume mechanism if you were using absolute extrusion or volumetric extrusion. I've just fixed those, the fixes will be in RC5.
                    NOW WORK !!!!!! thanks David DC2
                    Giorgio
                    -Albert Einstein
                      absolute extrusion …..Simply3D v4
                      -Albert Einstein
                        6:45:31M98 P0:/macros/RICUPERO Down Power
                        File Test100.gcode selected for printing
                        16:42:09Connection established!
                        16:42:04Disconnected.
                        16:37:25Attempt to move the head of a Delta or SCARA printer before homing the towers
                        16:37:21M80
                        Error: Homing failed
                        16:36:50Connection established!
                        16:36:44Disconnected.
                        16:36:32Print cancelled due to low voltage
                        Printing resumed
                        16:36:29Resume-after-power-fail state saved
                        Print auto-paused due to low voltage
                        Print auto-resumed
                        16:32:33M98 PRESURRECT.G
                        16:30:40Attempt to move the head of a Delta or SCARA printer before homing the towers
                        16:30:36G28
                        HOME PROBLEMS ??
                        -Albert Einstein
                          As far as I can see, there are no commands in resurrect.g prior to the M98 Presurrect-prologue.g call that command movement. So it sounds to me like the G28 command in resurrect-prologue.g failed. A common reason for homing failures in delta printers is that the G1 S1 command in homedelta.g has X, Y and Z parameters that are less than the maximum distance you may need to move the carriages to home them.
                            Ok ….just one little BUG
                            M291: Display message and optionally wait for response
                            Supported in firmware version 1.19beta7 and later.
                            Parameters
                            P"message" The message to display, which must be enclosed in double quotation marks. if the message itself contains a double quotation mark, use two double quotation marks to represent it.
                            R"message" Optional title for the message box. Must be enclosed in double quotation marks too.
                            Sn 0 = no acknowledgement needed (default), 1 = display an OK button and wait for it to be pressed (the user interface then sends M292 to indicate that is has been acknowledged)
                            Tn Timeout in seconds, ignored if S=1. The message will be cancelled after this amount of time, if the user does not cancel it before then. A zero or negative value means that the message does not time (it may still be cancelled by the user). The default value is 10 seconds
                            Zn 0 = no special action, 1 = display Z jog buttons alongside the message to allow the user to adjust the height of the print head
                            if set Z0 appear the jog control ,also is set Z1 😉
                            -Albert Einstein
