    Power Failure
    Firmware installation
    2.6k
      What I meant was: if you send M98 Presurrect.g, does anything happen at all? Do you get any messages in the Console window of DWC?
      Please post the contents of resurrect.g.
      • TYPPA Albert Einsteinundefined
        on config,g
        ;Power Failure
        M911 S6.0:9.75:11.0 ; PSU 12V
        Editing 0:/sys/resurrect.g
        ; File "Test100.gcode" resume print after auto-pause at 2017-07-07 11:33
        M140 S40.0
        G10 S212 R0
        T0 P0
        G92 E6.965
        G29 S1
        M98 Presurrect-prologue.g
        M106 P0 S0.00
        M106 P1 S0.00
        M106 P2 S0.00
        M106 P3 S0.00
        M106 P4 S0.00
        M106 P5 S0.00
        M106 P6 S0.00
        M106 P7 S0.00
        M106 P8 S0.00
        M106 S0.00
        M116
        M290 S0.000
        M23 Test100.gcode
        M26 S6011
        G1 F6000 X-52.85 Y51.40 Z0.20
        G1 F1470.0 P0
        M24
        Send on DWC M98 Presurrect.g
        reponse from DWC
        15:47:25M98 PRESURRECT.G
        Macro file resurrect-prologue.g not found.
        on SYS Editing 0:/sys/resume-prologue.g
        M116
        G28
        M83
        G1 E2 F3600
        NOT the file resurrect-prologue.g ?
        I have no special talent. I am only passionately curious.
        -Albert Einstein
          I'm sorry, you need to rename resume-prologue.g to resurrect-prologue.g. I changed the filename during development, and when I updated that wiki page I updated all occurrences of that filename… except one. I've corrected it now.
            Ok i test now ….thaks David
            i post after the result
            -Albert Einstein
              There is a bug in the resume mechanism if you were using absolute extrusion or volumetric extrusion. I've just fixed those, the fixes will be in RC5.
                NOW WORK !!!!!! thanks David DC2
                Giorgio
                -Albert Einstein
                  absolute extrusion …..Simply3D v4
                  -Albert Einstein
                    6:45:31M98 P0:/macros/RICUPERO Down Power
                    File Test100.gcode selected for printing
                    16:42:09Connection established!
                    16:42:04Disconnected.
                    16:37:25Attempt to move the head of a Delta or SCARA printer before homing the towers
                    16:37:21M80
                    Error: Homing failed
                    16:36:50Connection established!
                    16:36:44Disconnected.
                    16:36:32Print cancelled due to low voltage
                    Printing resumed
                    16:36:29Resume-after-power-fail state saved
                    Print auto-paused due to low voltage
                    Print auto-resumed
                    16:32:33M98 PRESURRECT.G
                    16:30:40Attempt to move the head of a Delta or SCARA printer before homing the towers
                    16:30:36G28
                    HOME PROBLEMS ??
                    -Albert Einstein
                      As far as I can see, there are no commands in resurrect.g prior to the M98 Presurrect-prologue.g call that command movement. So it sounds to me like the G28 command in resurrect-prologue.g failed. A common reason for homing failures in delta printers is that the G1 S1 command in homedelta.g has X, Y and Z parameters that are less than the maximum distance you may need to move the carriages to home them.
                        Ok ….just one little BUG
                        M291: Display message and optionally wait for response
                        Supported in firmware version 1.19beta7 and later.
                        Parameters
                        P"message" The message to display, which must be enclosed in double quotation marks. if the message itself contains a double quotation mark, use two double quotation marks to represent it.
                        R"message" Optional title for the message box. Must be enclosed in double quotation marks too.
                        Sn 0 = no acknowledgement needed (default), 1 = display an OK button and wait for it to be pressed (the user interface then sends M292 to indicate that is has been acknowledged)
                        Tn Timeout in seconds, ignored if S=1. The message will be cancelled after this amount of time, if the user does not cancel it before then. A zero or negative value means that the message does not time (it may still be cancelled by the user). The default value is 10 seconds
                        Zn 0 = no special action, 1 = display Z jog buttons alongside the message to allow the user to adjust the height of the print head
                        if set Z0 appear the jog control ,also is set Z1 😉
                        -Albert Einstein
