    Restart after print start
    • Simon 0undefined
      Simon 0
      Hi guys,
      my printer always restarts after starting the G-Code. Duet is responding "Connection interrupted http request time out" (probably because of the restart and the failed connection). I restarted my router and used the wifi reset macro, but nothing worked. The same result by printing from SD-Card or PC. Do you guys have any ideas?
      Simon
        dc42 administrators @Simon 0
        @simon-0 if you ever get an unexpected reset of the Duet, run M122 as soon as it reconnects and post the result here.
        Simon 0undefined 1 Reply Last reply Reply Quote 0
        • Simon 0undefined
          Simon 0 @dc42
          @dc42 the result is in the text data, because of the spam filter
          M122.txt
            Last reset 00:00:37 ago, cause: power up
            The reset was caused by the PSU cutting out.
            • Simon 0undefined
              Simon 0 @dc42
              @dc42 how can i fix it?
              • Simon 0undefined
                Simon 0 @Simon 0
                Problem solved. The heater was broken. Thanks for helping!
