Need Help with Panel Due firmware update
I agree with Doug, you have probably downloaded the HTML page describing the firmware instead of the firmware binary (a common mistake with using github because users expect links whose text ends in ".bin" to be binaries, not HTML pages). Follow the link and when you get to the page describing just that file, press the Download button.
To get the Bossa port back,connect the USB cable, press the Erase button for a second or so, followed by the reset button.
You guys are great, that is it, my .bin is 34k. What can I do to get the board to reappear in device manager now so I can reflash the correct.bin? I've tried multiple usb ports and rebooting, and "scan for hardware changes".
press the erase button for a few seconds and then the reset button and it should appears in DM as a bossa port then flash away
SUCESS!
Thank you all
Next hurdle:
I successfully updated the panelDue firmware, Reprap firmware, wifi firmware, and web console firmware.
Now when i copy the config.g from https://github.com/mzbotreprap/VORON/tree/master/Firmware/DuetWifi/yonkiman/sys
the panel due boots up with the expected configuration but the screen flashes on and off. I tried using the corexy config.g supplied by filastruder on the microSD card and get the exact same result. Any Ideas? -
How are you powering the Duet?
I am powering the duet via usb. I tried via "high power" usb port on my laptop and through a powered hub. The screen did not blink with the default kossel configuration file from filastruder
USB ports often can't supply enough power for the Duet+PanelDue. The configuration file likely has some differences that result in a different power draw. Best to power using the screw terminals.
That was it. I'm powering it from the 24V PS and its solid.
Sorry for hijacking this thread, but i've got kinda the same problem.
Updated FW from 1.15c to 1.16 for the 5" PanelDue. After flash i hit reset. But it stays black and it appears no longer in the device manager. Any way to "jump start" the panel?
Message in cmd:
C:\Users\Grafikbitch\Downloads\bossa>bossac.exe --port=COM6 -e -w -v -b PanelDue-5.0-1.16.bin Erase flash Write 130720 bytes to flash [==============================] 100% (511/511 pages) Verify 130720 bytes of flash [==============================] 100% (511/511 pages) Verify successful Set boot flash true C:\Users\Grafikbitch\Downloads\bossa>
That's odd, I can't see anything wrong in your description.
You can connect the Duet to a PC via USB and run Pronterface or a terminal emulator program on the PC for debugging. If you send M111 S1 P3 to the Duet, it will echo all commands received to the USB port. If you see any lines starting with "aux:" then the PanelDue is sending status requests to the Duet.
That's what i thought too
I turned debugging on an used your mentioned M111 command and there is no line with "aux".
SENT: M111 S1 P3 READ: serial: M111 S1 P3 READ: Debugging enabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) ?(12) READ: Debugging disabled for modules: READ: ok SENT: M105 READ: serial: M105
The output "READ: serial: M105" then repeats every second or so.
Tried this with printer normal powered on, turned off and powered over the USB. USB every time connected over the duet to the pc.
Maybe the output power for the Due is faulty? But on the other hand it will also not turn on when i connect the Due over USB to the PC.
Try downloading and flashing the firmware again, in case the firmware somehow got corrupted in the process.
Did you separate the PanelDue controller and the TFT panel at any stage? If so, are you sure that you lined them up properly when you put them back together?
No i didn't and now it gets weirder.
I dissasembled the due controller from the panel, removed the power wire from controller and duet. Re-assembled and⦠it works ^^
I don't knwo what the heck happened but all is good
Maybe it was the dissassembly or the whole day without plugged in while i am at work.
Thx again
I'm glad it's working. I suspect a bad connection.
