    Strange bugs 3.3beta2
    Beta Firmware
    8
    48
    2.4k
      Next time one of you get these "Bad command" messages on PanelDue, please run M122 from the DWC console or USB. I am especially interested in what value it reports for "Aux0 errors".
      Depundefined psychotik2k3undefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @Dep
        @Dep said in Strange bugs 3.3beta2:
        Another dangerous bug!
        M558 K0 H5 A5 F120
        Works as it should
        M558 K0 H5 A5 F120: 120
        Also works as it should
        M558 K0 H5 A5 F120: 60
        Broke today probe.
        The bed goes up and breaks the probe. And continue to rise.
        I checked it several times.
        What type of probe is it? Some types of probe (e.g. Smart Effector and piezo probes) don't work at low speeds.
        • Depundefined
          Dep
          Simple micro switch.
          • Depundefined
            Dep @dc42
            @dc42 I can't yet, because I installed version 3.2.2 and the messages disappeared.
            • psychotik2k3undefined
              psychotik2k3 @dc42
              @dc42 here it is:
              24/05/2021, 22:20:04	M122
              RepRapFirmware for Duet 3 MB6HC version 3.3RC2 (2021-05-11 14:55:28) running on Duet 3 MB6HC v1.01 or later (standalone mode)
              Board ID: 08DJM-956BA-NA3TN-6JTD8-3S86J-1UB2T
              Used output buffers: 1 of 40 (40 max)
              Static ram: 150680
              Dynamic ram: 93532 of which 108 recycled
              Never used RAM 107016, free system stack 120 words
              Tasks: NETWORK(ready,445.1%,226) ETHERNET(notifyWait,1.3%,124) HEAT(delaying,0.2%,295) Move(notifyWait,0.6%,242) CanReceiv(notifyWait,0.3%,773) CanSender(notifyWait,0.0%,373) CanClock(delaying,0.1%,341) TMC(notifyWait,128.2%,59) MAIN(running,312.5%,619) IDLE(ready,0.0%,29), total 888.3%
              Owned mutexes:
              Last reset 03:22:59 ago, cause: software
              Last software reset at 2021-05-24 18:57, reason: User, GCodes spinning, available RAM 110188, slot 0
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
              Error status: 0x04
              Aux0 errors 9,9,9
              Aux1 errors 0,0,0
              Step timer max interval 133
              MCU temperature: min 40.4, current 42.5, max 43.1
              Supply voltage: min 23.3, current 23.7, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
              Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/40/40, gc cycles 0
              Driver 0: position 12600, standstill, reads 41045, writes 30 timeouts 0, SG min/max 0/212
              Driver 1: position -22000, standstill, reads 41046, writes 30 timeouts 0, SG min/max 0/212
              Driver 2: position 4272, standstill, reads 41046, writes 30 timeouts 0, SG min/max 0/173
              Driver 3: position 0, standstill, reads 41046, writes 30 timeouts 0, SG min/max 0/168
              Driver 4: position 0, standstill, reads 41065, writes 11 timeouts 0, SG min/max 0/0
              Driver 5: position 0, standstill, reads 41066, writes 11 timeouts 0, SG min/max 0/0
              Date/time: 2021-05-24 22:18:43
              Slowest loop: 13.29ms; fastest: 0.05ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 2.2ms, write time 2.0ms, max retries 0
              DMs created 125, maxWait 8863916ms, bed compensation in use: mesh, comp offset 0.038
              === MainDDARing ===
              Scheduled moves 410, completed moves 410, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === CAN ===
              Messages queued 110176, send timeouts 0, received 146584, lost 0, longest wait 2ms for reply type 6018, peak Tx sync delay 284, free buffers 49 (min 48)
              === Network ===
              Slowest loop: 5.93ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
              - Ethernet -
              State: active
              Error counts: 0 0 1 0 0
              psychotik2k3undefined 1 Reply Last reply Reply Quote 0
                psychotik2k3 @psychotik2k3
                @psychotik2k3 and i reproduce for example when doing a bed leveling from the panel due (and other stuffs)
                the gcode executed is this one:
                ; bed.g
                if (move.axes[2].homed=false )
                	echo "homing Z axis"
                	M98 P"homez.g"
                G30 P0 X297 Y154 Z-99999 s-1
                G30 ; home
                ;for bltouch
                G30 P0 X297 Y154 Z-99999 ; probe near a leadscrew, half way along Y axis
                G30 P1 X9 Y154 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                  @psychotik2k3 and i have these errors since today when i switched from 3.2.2 stable to 3.3 RC2
                  allways a bad command * M409 *
                  • oozeBotundefined
                    oozeBot
                    This appears related to something we just caught as well on a 3.3-rc2 machine running on a 6HC + SBC. We never saw issues like this on 3.2..
                      psychotik2k3 @oozeBot
                      @oozebot i think there will be either an RC4 or the RC3 will be delayed a little
                        There will be an RC3 coming shortly.
                        @oozeBot @psychotik2k3 What paneldue firmware version?
                        oozeBotundefined 1 Reply Last reply Reply Quote 0
                        • oozeBotundefined
                          oozeBot @Phaedrux
                          @phaedrux I just checked and that machine is on 3.2.10.
                            @psychotik2k3 was in 3.2.10 and when having these errors i went to latest 3.2.11 and got same problems
                              @psychotik2k3 for now this is the last bug i have so far with 3.3 RC3+6 🙂
