    WiFi reported error: no known networks found
    Firmware installation
    • Raffa2sundefined
      Raffa2s
      In the last few days, I had tried to connect to my Duet2 wifi as always but I couldn't (server unreachable). I had tried to reset the firmware but nothing... How can I fix that?
      Down below you can find the state of M587 and M552 S1, after that the error "WiFi reported error: no known networks found" even if the wifi is listed.
      Send: M587
      Recv: Remembered networks:
      Recv: CASARAF IP=192.168.1.29 GW=0.0.0.0 NM=0.0.0.0
      Recv: ok
      Send: M552 S1
      Recv: ok
      Recv: WiFi reported error: no known networks found
      Recv: WiFi module is idle
      thank you
        jay_s_uk @Raffa2s
        @raffa2s the SSID is case sensitive. Is your wifi network name all in capitals?
        What terminal software did you use?
        Raffa2sundefined 1 Reply Last reply Reply Quote 0
        • Raffa2sundefined
          Raffa2s @jay_s_uk
          @jay_s_uk I just write it right but it's appears like that, is it normal?
          Octoprint as terminal was used
            jay_s_uk @Raffa2s
            @raffa2s I believe octoprint capitalises every letter. So if you have anything lowercase in your password or SSID you need to use ' in front of each letter as described here https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
            If you're reading the same network I suggest starting a fresh by deleting all known networks using M588 S"*"
            • Raffa2sundefined
              Raffa2s @jay_s_uk
              @jay_s_uk ok I try
