    New heater tuning algorithm
    Beta Firmware
    33
    131
    18.1k
    • Deltasquareundefined
      Deltasquare @MikeS
      @MikeS
      I am 100% sure. 😄
      However it's not quite up there with the Marlin engine in sophistication.... but close. 😉
      • Alucardiundefined
        Alucardi
        This post is deleted!
        • lee7670undefined
          lee7670
          @dc42 now that 3.2 has been out for some time, would it be possible to get a better description of what the new M307 parameters do? the documentation is very vague and (https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control#Section_Manual_adjustments_to_the_heater_model_parameters) still refers to the deprecated parameter A (gain). Specifically, heater rate has no units on it. Would it be possible to see a quick diagram of what the heater loop looks like and where all the parameters feed in? I'll need to have one of our controls engineers fix a particularly troublesome heater and it would be good if they had a diagram of what's going on so we can tune on the fly.
            dc42 administrators @lee7670
            @lee7670 I have updated the wiki page on heater tuning.
            lee7670undefined 1 Reply Last reply Reply Quote 0
            • lee7670undefined
              lee7670 @dc42
              @dc42 Thank you, this is very useful!
              • gorf26undefined
                gorf26
                Seeing the subject has been brought up again..
                I have just change out my hotend and heater and tried auto tune, always finishes but seems to have errors and gives me the values for the 307 in config, after entering the new values and i turn on the heater to 210 i always get a heater fault not rising fast enough. but from watching the DWC the temp seems to be going up fast.
                So returned and this time no error and a new pid value so i enter that and got the same heater fault
                If i put just use the default m307 values with no pid values it heats up fine no errors..
                also have a pt100 with the duet pt100 board and it a diet2 wifi
                this is with firmware 3.2.2 release
                Thanks gary
                Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @gorf26
                  @gorf26 Instead of manually copying the values, can you try using M500 to save them to config-override.g and then compare what you had to what it saved. See if there is a difference. What values are they?
                    dc42 administrators @gorf26
                    @gorf26 what M307 values does it tell you to use when you tune it?
                    gorf26undefined 1 Reply Last reply Reply Quote 0
                    • gorf26undefined
                      gorf26 @dc42
                      M307 H0 B0 A113.8 C611.3 D0.4 V23.0
                      I have gone ahead and installed 3.3RC3 and that has seemed to fix it, I tuned the hotend again and it tuned with no errors, used the m307 it suggested and when cooled down i heated it to 240c and no fault error now.
                      Still a little trouble with the bed tuning gives me a waring message every time and a suggested a m307 value
                      i enter that in the config and it heats up fine.. so guess i won't worry about it to much..
                      Thanks gary
                        @gorf26 said in New heater tuning algorithm:
                        The warning is normal. It's telling you how hot it predicts the heater could get in a failure situation.
