[3.3rc3] G28 inside bed.g blocks the macro
Hi Duet team and fellow readers,
I've made a whole new setup with the config tool for my Delta printer.
Something weird happens, when I want to calibrate the printer. 'bed.g' stops after 'G28' without any notification.
I also ran it through M98 p"bed.g", but got no errors or warnings. It just stops...
So I commented the line in the macro and send a G28 from console before G32 et voila it works?!My bed.g
; bed.g ; called to perform automatic delta calibration via G32 M561 ; clear any bed transform ;G28 ; home all towers <<<=== had to comment out to make it work G1 z10 f6000 ; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g. G30 P0 X0 Y79.9 H0 Z-99999 G30 P1 X69.2 Y-39.95 H0 Z-99999 G30 P2 X-69.2 Y-39.95 H0 Z-99999 G30 P3 X0 Y39.9 H0 Z-99999 G30 P4 X34.55 Y-19.95 H0 Z-99999 G30 P5 X-34.55 Y-19.95 H0 Z-99999 G30 P6 X0 Y0 H0 Z-99999 S6
...and homedelta FWIW
; homedelta.g G91 ; relative positioning G1 H1 X545 Y545 Z545 F6000 ; move all towers to the high end stopping at the endstops (first pass) G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm G1 H1 X10 Y10 Z10 F500 ; move all towers up once more (second pass) G1 Z-10 F6000 ; move down a few mm so that the nozzle can be centred G90 ; absolute positioning G1 X0 Y0 F6000 ; move X+Y to the centre
@o_lampe please try the firmware at https://www.dropbox.com/sh/nmpsl9a3jfsumm5/AAA6adSjEcd1AM_j5_tVberGa?dl=0. This firmware may provide an additional diagnostic.
FWIW, homing in bed.g works for me. My bed.g file is this:
; Auto calibration routine for large delta printer M561 ; clear any bed transform ; If the printer hasn't been homed, home it if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed G28 ; Probe the bed and do auto calibration G1 X0 Y140 Z10 F12000 ; go to just above the first probe point while true if iterations = 5 abort "too many auto calibration attempts" G30 P0 X0.00 Y140.00 Z-99999 if result != 0 continue G30 P1 X70.00 Y121.24 Z-99999 if result != 0 continue G30 P2 X121.24 Y70.00 Z-99999 if result != 0 continue G30 P3 X140.00 Y0.00 Z-99999 if result != 0 continue G30 P4 X121.24 Y-70.00 Z-99999 if result != 0 continue G30 P5 X70.00 Y-121.24 Z-99999 if result != 0 continue G30 P6 X0.00 Y-134.85 Z-99999 if result != 0 continue G30 P7 X-65.57 Y-113.57 Z-99999 if result != 0 continue G30 P8 X-112.29 Y-64.83 Z-99999 if result != 0 continue G30 P9 X-130.59 Y-0.00 Z-99999 if result != 0 continue G30 P10 X-115.90 Y66.91 Z-99999 if result != 0 continue G30 P11 X-69.45 Y120.29 Z-99999 if result != 0 continue G30 P12 X0.00 Y70.00 Z-99999 if result != 0 continue G30 P13 X60.62 Y-35.00 Z-99999 if result != 0 continue G30 P14 X-52.28 Y-30.19 Z-99999 if result != 0 continue G30 P15 X0 Y0 Z-99999 S8 if result != 0 continue if move.calibration.final.deviation <= 0.033 break echo "Repeating calibration because deviation is too high (" ^ move.calibration.final.deviation ^ "mm)" ; end loop echo "Auto calibration successful, deviation", move.calibration.final.deviation ^ "mm" G1 X0 Y0 Z150 F10000 ; get the head out of the way
thanks for the cool macro.
Do you think it would be useful to make it 'universal' by calculating the probe points, based on the "B" parameter in M665? -
The rc3+6 update made it!
@o_lampe said in [3.3rc3] G28 inside bed.g blocks the macro:
Probably, assuming that the entire bed within the B radius is reachable by the nozzle, and that you don't want to probe outside it.
