    [3.3RC3] Missed stepps or overdue moves
    Beta Firmware
    1.3k
    • TypQxQundefined
      TypQxQ @dc42
      @dc42 I haven't experienced any issues with the board reseting.
      I use 3 ways of reseting the board:
      1. Emergency Stop button in Web interface.
      2. Emergency Stop button on mains power.
      3. Emergency reset button and endstops mapped to Trigger file:
      M25
      M122 B0
      M122 B1
      M112
        dc42 administrators @TypQxQ
        @typqxq those lines in the M122 B1 report indicate that the expansion board reset at some point. We need to establish whether that happened during the print, or a long time ago. If it did occur during the print, that would account for the maxOverdue value being so high.
        Please do the following:
        1. Upgrade the main board and expansion board firmwares to the versions at https://www.dropbox.com/sh/nmpsl9a3jfsumm5/AAA6adSjEcd1AM_j5_tVberGa?dl=0. Ignore the .map files.
        2. Send M122 B1 P1004.
        3. Run M122 B1 and check that the M122 report shows the software reset reason as "deliberate HardFault zeroDiv".
        4. Reset the main board.
        5. Try a print.
        TypQxQundefined 1 Reply Last reply Reply Quote 0
        • TypQxQundefined
          TypQxQ @dc42
          @dc42 Made the above steps and I can't see any change. Here is the new logs event_rc3+1.txt . It's too long for the post limit.
            @typqxq thanks, I will try to replicate your setup today.
              @typqxq said in [3.3RC3] Missed stepps or overdue moves:
              Here is a link to the configuration and a test gcode file https://we.tl/t-DQueVGrH61
              Unfortunately that .link has expired. Please provide a new link to your files.
              • TypQxQundefined
                TypQxQ @dc42
                @dc42 Here is a new link: https://www.dropbox.com/sh/yfjwidhzvlxk8k2/AAAQd95XneD8zUVNV8VnNO3ya?dl=0
                dc42undefined 2 Replies Last reply Reply Quote 0
                  @typqxq thanks.
                  I have spotted an error in your configuration, in file custom/tool_1.g:
                  ; Create Heater
                  	M308 S2 P"2.temp1" Y"thermistor" T100000 B4725 C0.0000000706 A"T1 Heater"	; configure sensor 2 as thermistor on pin temp1
                  	M950 H2 C"2.out1" T2											; create nozzle heater output on out1 and map it to sensor 2
                  	M143 H2 S300													; set temperature limit for heater 1 to 300C (e3d v6 all metal)
                  	M307 H2 B0 S1.00												; disable bang-bang mode for heater  and set PWM limit
                  ; Create Part Fan
                  	M950 F3 C"2.out4"	                            ; Define Part Cooling fan on out4 (4pin)
                  	M106 P3 C"Part Cooling T1"						; Setup Part Cooling Fan as Part Cooling T1
                  ; Create Hotend Fan
                  	M950 F4 C"1.out7"	                            ; Define Hotend Fan on out7 (2pin)
                  	M106 P4 S255 T45 H2                             ; Setup Hotend Fan for thermal control, full on when H2 reaches 45C
                  You create the sensor and heater on board 2, but the fan on board 1. RRF has the following documented limitation:
                  A thermostatically-controlled fan on an expansion board can only be controlled by a temperature sensor on the same expansion board.
                  Did you perhaps mean to use port 2.out7 for the fan?
                  I don't know whether this is relevant to the problem of maxOverdue being much too large and the associated print issues. I will change the config to use port 2.out7 and try running your print.
                    @typqxq I have reproduced the problem on my bench system so I am now able to investigate it.
                    For future reference, it would be easier for me to use your configuration files if instead of using M98 P"/sys/custom/xxx" in many places, you used M98 P"custom/xxx". This is because I have your configuration in a subfolder of /sys.
                    • TypQxQundefined
                      TypQxQ @dc42
                      @dc42 Thank you, I found and fixed it last week. It had no effect from what I can see.
                      This are the configuration files as of when I reported the problem.
                        @typqxq please try the new firmware binaries at https://www.dropbox.com/sh/xfsvscbaab0dtzl/AACCcSeiTNINZL-xbs6IhC4Ja?dl=0. Ignore the .map files.
                          dc42 administrators @dc42
                          @TypQxQ have you had a chance to try the new firmware? We're waiting to release 3.3 stable but I would like to know whether this issue is resolved first.
                          TypQxQundefined MaxGyverundefined 2 Replies Last reply Reply Quote 0
                          • TypQxQundefined
                            TypQxQ @dc42
                            @dc42 Sorry but I have left on vaccation and won’t be able to test it until I get back.
                            Have a great summer!
                            • MaxGyverundefined
                              MaxGyver @dc42
                              @dc42 I had the same problems described by @TypQxQ after upgrading from RC3.2 to RC3.3.
                              The new binaries fixed the issue.
                              Cheers
                              Max
                                dc42 administrators @MaxGyver
                                @maxgyver said in [3.3RC3] Missed stepps or overdue moves:
                                Cheers
                                Max
                                Thanks for confirming that!
                                • MaxGyverundefined MaxGyver referenced this topic
