Home Y not reading all lines of code
Duet Web Control
    PRIOR123
    Hi All,
    I hope you can help,
    Trying to work out my homing issues. for my Y axis It doesn't seem to be reading the H1 code. It seems to be jumping straight to the move a few mm line. can some help?
    G91 ; relative positioning
    G1 H2 Z-5 F6000 ; lift Z relative to current position
    G1 H1 Y235 F1800 ; move quickly to Y axis endstop and stop there (first pass)
    G1 H2 Y-5 F6000 ; go back a few mm
    G1 H1 Y235 F360 ; move slowly to Y axis endstop once more (second pass)
    G1 H2 Z-5 F6000 ; lower Z again
    G90 ; absolute positioning
    This is my homey.G
    undefined 1 Reply Last reply 20 Jun 2021, 21:16 Reply Quote 0
      jay_s_uk @PRIOR123
      @prior123 I suggest checking your endstops are working as intended using M119
      undefined 1 Reply Last reply 20 Jun 2021, 21:20 Reply Quote 0
        PRIOR123 @jay_s_uk
        @jay_s_uk said in Home Y not reading all lines of code:
        M119
        Hey, so you were right the Y end stop was properly connected (facepalm) however it that is now fixed but is still giving me the same outcome
        undefined 1 Reply Last reply 20 Jun 2021, 21:52 Reply Quote 0
          fcwilt @PRIOR123
          @prior123
          That behavior suggests that the endstop is triggered when it should not be.
          So the first move never happens because a G1 H1 stops when the endstop is triggered.
          The second move happens because it is not a G1 H1 move.
          The third move never happens because a G1 H1 stops when the endstop is triggered.
          2 out of 4
