    X axis homes to the wrong direction
    2.3k
    • eviltoyundefined
      eviltoy
      Hi
      So I have been trying to figure out how to change the X home direction but alas I am failing. This all started with trying to get the axis actually moving in the right planes. Y moves home in the direction I want now etc but X still gives me hassles as it wants to home to the + side. How can I set this in firmware? I believe the 569 setting needs to be changed however if I change this it just makes everything go in diagonals. i have also tried switching the between the drivers but I still end up in the same place. config as follows:
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Sun Aug 13 2017 15:24:35 GMT+0200 (South Africa Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      G90 ; Send absolute coordinates…
      M555 P2 ; Set firmware compatibility to look like Marlin
      M667 S1 ; Select CoreXY mode
      M208 X400 Y400 Z400 S0 ; Set axis maxima
      M574 Z0 S0 ; Define active low and unused microswitches
      M574 X1 Y2 S1 ; Define active high microswitches
      M558 P4 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:385 Y15:385 S20 ; Define mesh grid
      M569 P0 S0 ; Drive 0 goes forwards
      M92 X174.978 Y174.978 Z400 E417 ; Set steps per mm
      M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X9000 Y9000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1000 I60 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S260 ; Set maximum heater temperature to 260C
      M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      Fancy network stuff goes here.
      M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        deckingman
        This is usually caused by one of the motor directions (M569) being incorrect. You can try this https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_CoreXY_printer#Movement_section
        Alternatively, there are only 4 possible combinations so you can use trial and error. Assuming your two XY drives are P0 and P1, the combinations are:
        P0 S0 and P1 S0
        P0 S0 and P1 S1
        P0 S1 and P1 S0
        P0 S1 and P1 S1.
        • eviltoyundefined
          eviltoy
          Sorted had to change the second line to S1. Now when I home after it hits the endstops there is a screeching noise.
          • eviltoyundefined
            eviltoy
            M569 P1 S0 ; Drive 1 goes forwards
            Sorry my english is failing me today I meant I had to do this after I swapped the drivers around. Now just that screeching noise and to get Z to actually home
              Is it just a problem with X homing in the wrong direction, or are the X jog buttons also moving the head the wrong way?
              Which corner of the bed are you calling X=0 Y=0, and which directions are you calling +X and +Y ?
              • eviltoyundefined
                eviltoy
                all jogs right now from what I can see. Just z does not home when homing all axis now
                  See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer#Homing_Z.
                  • eviltoyundefined
                    eviltoy
                    Got it thank you so much its homing now. And its just the mesh levelling that I need to sort out. Seems it probes a few points then says that that the probe was activated at the next point already.
                      Increase the dive height. It's the H parameter in the M558 command.
