    Start / Stop S3D SCRIPT / G-CODE
    2.5k
    • noblebranundefined
      noblebran @fcwilt
      @fcwilt I will fully admit I can't follow it. My script for my TLM pre-duet was a few lines. I am lost on how to get it so it doesn't a single probe to get the right height and get up axis.
      I own a Tevo Little Monster but there isn't much left of that except for the frame. Duet 2 Wifi + PanelDue 7i.
      • fcwiltundefined
        fcwilt @noblebran
        @noblebran said in Start / Stop S3D SCRIPT / G-CODE:
        @fcwilt I am lost on how to get it so it doesn't a single probe to get the right height and get up axis.
        I'm sorry but I don't understand the question.
        If you are asking about setting the Z=0 datum that happens in the "mesh_comp_map_load.g".
        One of the things that you always do before loading the height map is setting the Z=0 datum.
        I have it in that file to be sure the height map is loaded correctly.
        Here is a simplified version of that file:
        M98 P"probe_set_z.g"; set Z=0 Datum
        G29 S1              ; load existing height map
        M376 H0             ; set bed compensation taper (0 = no taper)
        noblebranundefined 1 Reply Last reply Reply Quote 0
          noblebran @fcwilt
          @fcwilt said in Start / Stop S3D SCRIPT / G-CODE:
          M98 P"probe_set_z.g"; set Z=0 Datum G29 S1 ; load existing height map M376 H0 ; set bed compensation taper (0 = no taper)
          I must be really ignorant... I don' have a "mesh_comp_map_load.g" 🙇
          • fcwiltundefined
            fcwilt @noblebran
            Where you see M98 P"...." that M98 command is executing a file that I created to perform a specific task.
            Whenever I have a hunk of code I need to execute from more than one location I place that code in a separate file that I can invoke as needed with M98. That way I don't have any duplicate code appearing in multiple locations.
            The common files you are likely to see are:
            • config.g
            • homeall.g
            • homex.g
            • homey.g
            • homez.g
            • bed.g
            • mesh.g
            In addition to these I have 27 other files of my own creation that perform specific tasks.
              noblebran @fcwilt
              @fcwilt Okay, thank you for the explanation my friend.
              • fcwiltundefined
                fcwilt @noblebran
                Glad to help.
                Do not hesitate to ask any questions you may have - that's how we all learn.
                  noblebran @fcwilt
                  @fcwilt I have no clue or have a start of where I need to go, but am not close to you....
                  • fcwiltundefined
                    fcwilt @noblebran
                    Well let's back up a bit.
                    What is it you want to do but don't know how to do?
                    I and others here can provide simple step by step code/instructions to do anything that needs to happen at the start of a print or the end of a print.
                      noblebran @fcwilt
                      @fcwilt Right now I don't have any code (except old Little Monster Smoothieware code) and I went to print something and the z-probe didn't extend and the height went to low, I did the offset and have done the work to get it all set up, but don't know how to start it and how to end the code. This is all new to me, and it was unexpected. The MKS Base card burnt out so I went with the Duet and have not had the time to do my research like I always like to do. I just don't want to break something in the process.
                      • fcwiltundefined
                        fcwilt @noblebran
                        @noblebran
                        Have you created the basic files I mentioned and have you installed them on the Duet?
                        • config.g
                        • homeall.g
                        • homex.g
                        • homey.g
                        • homez.g
                          noblebran @fcwilt
                          @fcwilt Sorry I was in bed and working now. I have done all (not to say they are right or not).
                          fcwiltundefined 2 Replies Last reply Reply Quote 0
                          • fcwiltundefined
                            fcwilt @noblebran
                            OK lets check those files.
                            using the </> tag post copy&paste the contents of each file in a separate tag.
                            The </> tag creates a scrollable region and makes viewing code easy.
                            noblebranundefined 5 Replies Last reply Reply Quote 0
                              noblebran @fcwilt
                              @fcwilt config.g
                              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Jul 05 2021 14:33:32 GMT-0400 (Eastern Daylight Time)
                              G90                                                ; send absolute coordinates...
                              M83                                                ; ...but relative extruder moves
                              M550 P"My Printer"                                 ; set printer name
                              M665 R155 L397.15 B155 H520                        ; Set delta radius, diagonal rod length, printable radius and homed height
                              M666 X0 Y0 Z0                                      ; put your endstop adjustments here, or let auto calibration find them
                              M552 S1                                            ; enable network
                              M587 S"XXXXXX"			   ; CONFIGURE AP
                              M586 P0 S1                                         ; enable HTTP
                              M586 P1 S1                                         ; enable FTP
                              M586 P2 S1                                         ; enable Telnet
                              M569 P0 S1                                         ; physical drive 0 goes forwards
                              M569 P1 S1                                         ; physical drive 1 goes forwards
                              M569 P2 S1                                         ; physical drive 2 goes forwards
                              M569 P3 S0                                         ; physical drive 3 goes forwards
                              M584 X0 Y1 Z2 E3                                   ; set drive mapping
                              M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                              M92 X160.00 Y160.00 Z160.00 E873.08                ; set steps per mm
                              M566 X1200.00 Y1200.00 Z1200.00 E1200.00           ; set maximum instantaneous speed changes (mm/min)
                              M203 X72000.00 Y72000.00 Z72000.00 E1200.00        ; set maximum speeds (mm/min)
                              M201 X2000.00 Y2000.00 Z2000.00 E1000.00           ; set accelerations (mm/s^2)
                              M906 X1200 Y1200 Z1200 E1200 I30                   ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30                                            ; Set idle timeout
                              M208 Z0 S1                                         ; set minimum Z
                              M574 X2 S1 P"xstop"                                ; configure active-high endstop for high end on X via pin xstop
                              M574 Y2 S1 P"ystop"                                ; configure active-high endstop for high end on Y via pin ystop
                              M574 Z2 S1 P"zstop"                                ; configure active-high endstop for high end on Z via pin zstop
                              M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
                              M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X0 Y20 Z1.35                              ; set Z probe trigger value, offset and trigger height
                              M557 R150 S45                                      ; define mesh grid
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
                              M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                              M307 H1 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
                              M140 H0                                            ; map heated bed to heater 0
                              M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                              M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
                              M950 H1 C"e1heat" T1                               ; create nozzle heater output on e1heat and map it to sensor 1
                              M307 H1 B0 R3.660 C138.7 D14.26 S1.00 V23.1        ; disable bang-bang mode for heater  and set PWM limit
                              M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
                              M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                              M106 P0 S1 H0 T50                                  ; set fan 0 value. Thermostatic control is turned on
                              M563 P0 D0 H1 F0                                   ; define tool 0
                              G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                              G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                              M575 P1 S1 B57600                                  ; enable support for PanelDue
                              M501											   ; for PID tuning
                                noblebran @fcwilt
                                @fcwilt homeall.g
                                G91                        ; relative positioning
                                G1 H1 X705 Y705 Z705 F3600 ; move all towers to the high end stopping at the endstops (first pass)
                                G1 H2 X-5 Y-5 Z-5 F3600    ; go down a few mm
                                G1 H1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
                                G1 Z-5 F6000               ; move down a few mm so that the nozzle can be centred
                                G90                        ; absolute positioning
                                G1 X0 Y0 F6000             ; move X+Y to the center
                                  noblebran @fcwilt
                                  @fcwilt homex.g
                                  G28 X ; home x
                                    noblebran @fcwilt
                                    @fcwilt homey.g
                                    G28 Y
                                      noblebran @fcwilt
                                      @fcwilt homez.g
                                      G28 Z
                                      • fcwiltundefined
                                        fcwilt @noblebran
                                        @noblebran
                                        Great.
                                        Now I don't have any delta printers so I had to check.
                                        For a delta printer the RRF configuration tool doesn't create those four homing files, just homedelta.g
                                        The homeall.g you posted looks like what the homedelta.g file should be.
                                        So get rid of homex.g homey.g and homez.g and then rename homeall.g to homedelta.g.
                                        Now with that out of the way let's turn to config.g.
                                        You have an M587 there which not be used in config.g. You use that command when setting up the WiFi connection but you don't keep it in config.g.
                                        At first glance everything else looks reasonable.
                                        Does the PanelDue work?
                                        Does homing work?
                                        Can you move the nozzle to all places in the printable area?
                                        Can you move over the range of the Z axis?
                                        If you move to Z=10 and do a G30 does the Z probe work?
                                        If you activate the heaters do they heat as expected to whatever temperature you specified?
                                        Do the fans work?
                                        noblebranundefined 1 Reply Last reply Reply Quote 1
                                          noblebran
                                          Great.
                                          Okay, this is done. Let me go to the next part.
                                            noblebran @fcwilt
                                            Does homing work?
                                            Do the fans work?
                                            My PanelDue 7i works, I haven't been able to print an enclosure for it so I haven't really been using it, but it connects and shows readings, etc.
                                            Homing does work.
                                            Yes, I can move the nozzle to all places in the printable area.
                                            I can move the nozzle over the range of the z axis using code, I can using the dashboard buttons. Homed it is x0, y0, z515 so when I put in a g1 z- command it goes down.
                                            The z-probe worked, re-calibrated just now (put the bed at z5, now its z6.35), I thought I put that correction in the config, but I guess not (as you know its the distance between the nozzle tip and tip of the probe).
                                            The heaters work, but I have another thread going as I always get faults that my block heater goes way above the set point. I have all e3d parts, I don't have an e3d cartridge thermistor but I didn't get one when I received the parts years ago and it worked when I had the old smoothieware system (MKS Base). The bed works great though.
                                            The fans work (I think). I say I think because my heatsink fan is on 24/7 now, which I know is because of the connection I plugged it in. My part cooling fans are set to turn on when the temp goes above 50 I think but I didn't know how else to control them as I would normally in the slicer.
                                            I did do an autocalibration and it worked
                                            Besides the extruder heater/thermistor and the fans (but they work) I think to answer everything I would say yes besides my comments above. Sorry for the abundance of detail.
