    Laser filament monitor 1.7 + RRF 3.3
    Filament Monitor
    438
    • c310undefined
      c310
      Hi! is there any way to make v.1.7 working with the latest firmware on the duetWiFi mainboar?
      or i have to purchase v.2.0 ? documentation mentions incompatibility and i can not make it running...
      led is flashing green and blue, cables are fine
      Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @c310
        @c310 said in Laser filament monitor 1.7 + RRF 3.3:
        Where do you see that?
        What command do you currently use to configure the sensor? How is it not working?
          dc42 administrators @c310
          That combination should work. The incompatibility is that newer versions of the filament monitor will not work with old versions of RRF that pre-date the newer filament monitor.
          Please tell us how you have connected the filament monitor to the Duet, and how you have configured it in config.g.
          c310undefined 1 Reply Last reply Reply Quote 0
          • c310undefined
            c310 @dc42
            monitor is connected with 3wire cable to E0 endstop header
            configuration
            M591 D0 P5 C"e0_stop" R15:120 E3.0 S1
            when print runs - it is being stopped with the 'too little movement' message.
            when checking M591 D0 console response is
            M591 D0 Duet3D laser filament monitor v1 on pin e0stop, enabled, allow 15% to 120%, check every 3.0mm, calibration factor 1.000, version 1, measured min 0% avg 0% max 0% over 10.9mm
            to continue printing i made
            M591 D0 S0
            with M591 D0 console shows
            M591 D0 Duet3D laser filament monitor v1 on pin e0stop, disabled, allow 15% to 120%, check every 3.0mm, calibration factor 1.000, version 1, measured min -1% avg 0% max 1% over 950.6mm
              https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_LaserVersion#Section_Calibration
              Based on your calibration result it looks like either the sensor isn't working or it really can't pickup your filament. What kind of filament are you using?
              What's your assembly like? Photo?
              There are some remixes for the laser monitor that use an indirect bearing instead of direct sensing, this removes the filament texture/gloss/etc from the equation.
              Try with different filament to see if it detects any better.
              • c310undefined
                c310 @Phaedrux
                @Phaedrux i have tried different filaments. shell is the most simple. It was working 6 month ago and than it was sitting in the cabinet. now i need it and it does not want to work 😞
                  It worked correctly 6 months ago?
                  Is the sensor dirty?
                  • c310undefined
                    c310 @Phaedrux
                    @phaedrux yes, it worked correctly. firmware was much lower than, but i do not remember the version
