    Duet2 wifi do not connect with USB
    • Jackundefined
      Jack
      I can't reach Duet2 wifi harware even with USB. Wifi is not responding so I tried with USB.
      But USB port is not available on PC. YAT or SerialTools do not recognize Duet.
      I tried to erase firmware to re-install. But nothing is responding when erase with jumper.
      3.3v LED is not running only 5v is lighting.
      Could you help?
      Best regards
      Eric
        Do the LEDs that light up change when you apply VIN power?
        Can you provide a higher resolution photo of the board in case we can see a failed component?
        Otherwise, please try working through this page https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
