Sensitivity and hot end fan.
Myabe mechanical vibrations not electrical interference are a culprit? If I recall it right sunon maglev has a more RPM's than usual ones.
Thanks David I'll try those things I didn't think it was vibration doing it.
Sounds very promising.
Cheers Zov it's a fast fan but not ridiculously so. And it's pretty smooth and quiet.
Looking forward for your results as it is my way in near future.
Okay so twisting fan wires - no joy.
Running fan at full power- no joy (I was anyway)
Disconnecting the fan whilst running and moving it slightly further out from the effector (so I presume it is no longer under the strain gauge traces seems to return the z-probe value to 0, instead of flickering triggered. So now printing a quick and dirty e3d fan shroud with 10mm lateral extension, with space for a cable tie if its not very tight when installed. -
Think I would have just done a 10mm extension piece rather than a full shroud
The one I was using was loose and a bit naff beforehand, on my previous setup I was using an integrated hotend fan and twin 30mm blowers but that won't fit on the smart effector. Plus its an excuse to design/print something with the machine now it has smart effector and nimble attached.
Copper foil around fan case at least between the fun and PCB? But it would be grounded somehow.
Edit: maybe somehow it is possible to turn the fan off before it touches the bed and turn it on after?
I bought an extra PCB effector, will see if I can mount a 200mW laser module to it, then I can re-use the 3 0.9degree steppers of my laser pcb exposer for a new delta build.
I hope that the z-sensing will also work with the laser, this way it should be much easier to adjust height before lasering.
Should work if you can tap the surface your etching/cutting with the laser unit (or a small rod as a proxy for a nozzle if that doesn't appeal). So long as its attached in the centre of the PCB and will flex the strain gauge traces.
Fixed. Moving the fan another 10mm out solved it, probing nicely now, hot end fan on or not.
https://s22.postimg.org/xxqo5r1qp/20170818_211915.jpg
sorry about the lighting those LED's are really bright.Thanks for the help. Very pleased with it, its a great product at a very fair price.
Now what else can be made from PCB's?Nice work. Do you mind sharing the dimensions you use on the interface of the e3d duct to mount onto the heat sink? I'm about to design the same type of shroud and wouldn't mind having the sizing/shape of the rounded "clamp" part that surrounds the heatsink correct the first time around.
I take no credit for that part see my thingiverse listing the original item is listed as a source.
Right, I forgot that e3d released the original Injection molding cad file, so I'll use that. Thanks!
