    After updating to 3.4.0beta2: faulty heater 1, -273.1C.
    Beta Firmware
    11
    121
    6.6k
    • Sergeundefined
      Serge @dc42
      @dc42 Ok, thanks. How to do that ? I have a SBC.
        dc42 administrators @Serge
        @serge I think your issue is different from the one reported by @juliann , because you are getting a temperature reading. What exactly is the symptom?
        Sergeundefined 1 Reply Last reply Reply Quote 0
        • Sergeundefined
          Serge @dc42
          @dc42 when i do an emergency stop, the system does not restart. I have to do a sudo reboot of the SBC and it takes a very long time to restart. When I then update the firmware of the toolboard, the temperature indicated is 2000 °. I have to turn off the Duet and restart it. The indicated temperature is then 10 ° lower and very unstable.
            @serge when the temperature reading is incorrect, what happens if you send:
            M98 P"config.g"
            Please post your config.g file.
            • juliannundefined
              juliann @dc42
              Thank you @dc42, I already corrected both commands in config.g and the behaviour is the same.
              Now I put v3.3 on the toolboard and the issue was fixed.
              What I am missing by using v3.3 on the toolboard, can I still testing input shaping or this feature is only available in 3.4?
              Thank you!
              dc42undefined 2 Replies Last reply Reply Quote 0
                dc42 administrators @juliann
                @juliann said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
                You can still test input shaping. Very little has changed in the expansion/tool board firmware.
                • Sergeundefined
                  Serge @dc42
                  @dc42 Enregistrement d'écran 2021-08-03 à 17.18.41.mp4
                  M98 P"config.g"
                  Error: Operation failed (Reason: NullReferenceException in SimpleCode: Object reference not set to an instance of an object.)
                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 18 2021 23:17:45 GMT+0200 (heure d’été d’Europe centrale)
                  G4 S1 ;wait for expansion boards to start
                  M550 P"Duet 3" ; set printer name
                  M669 K1 ; select CoreXY mode
                  G29 S1 ; Set Units to Millimeters
                  M569 P0.0 S0 D3 ; physical drive 0.0 goes forwards
                  M569 P0.1 S0 D3 ; physical drive 0.1 goes forwards
                  M569 P0.2 S0 D3 ; physical drive 0.2 goes forwards
                  M569 P0.3 S1 D3 ; physical drive 0.3 goes forwards
                  M569 P0.4 S1 D3 ; physical drive 0.4 goes forwards
                  M569 P20.0 S1 ; physical drive 20.0 goes forwards
                  M584 X0.4 Y0.3 Z0.0:0.1:0.2 E20.0 ; set drive mapping
                  M92 X80.00 Y80.00 Z800.00 E836.00 ; set steps per mm
                  M566 X2520.00 Y2520.00 Z480.00 E2520.00 ; set maximum instantaneous speed changes (mm/min)old 2520 for XY
                  M203 X30000.00 Y30000.00 Z900.00 E3600.00 ; set maximum speeds (mm/min)
                  M201 X3000.00 Y3000.00 Z320.00 E3600.00 ; set accelerations (mm/s^2)Old 3480 for XY
                  M906 X1600 Y1600 Z1200 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M671 X0:200:409 Y-2:407:-2 S5 ; define positions of Z leadscrews or bed levelling screws
                  M208 X410 Y400 Z400 S0 ; set axis maxima
                  M574 X1 S1 P"20.io1.in" ; configure active high endstops
                  M574 Y2 S1 P"io1.in" ; configure active high endstops
                  M558 P8 C"20.io0.in" I1 H3 F600 69000 ; set Z probe type to unmodulated and the dive height + speeds
                  G31 P1000 X-27.8 Y-12 Z1.668
                  M556 S280 X-1.25 Y0 Z0 ; set orthogonal axis compensation parameters; set Z probe trigger value, offset and trigger height
                  M557 X15:380 Y15:380 S35 ; define mesh grid
                  M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed" ; configure sensor 0 as thermistor on pin temp0
                  M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
                  M307 H0 B0 R0.706 C344.2 D4.98 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                  M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Hotend" ; configure sensor 1 as thermistor on pin 20.temp0
                  M950 H1 C"20.out0" T1 ; create nozzle heater output on 20.out0 and map it to sensor 1
                  M307 H1 B0 R5.925 C228.4:147.2 D9.34 S0.50 V24.0 ; disable bang-bang mode for heater and set PWM limit
                  M143 H1 S285 ; set temperature limit for heater 1 to 285C
                  M950 F1 C"20.out2" Q500 ; create fan 0 on pin 20.out2 and set its frequency
                  M106 P1 C"Hotend Fan" S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
                  M950 F0 C"20.out1" Q500 ; create fan 1 on pin 20.out1 and set its frequency
                  M106 P0 C"Layer Fan" S0 H-1 ; set fan 1 value. Thermostatic control is turned off
                  M955 P20.0 I24 S60 R10 ; Configure Accelerometer
                  M956 P20.0 S60 A0 ; Collect accelerometer data and write to file
                  ; EVA 2 / BMG / E3D V6
                  M92 E830 ; set extruder steps per mm, 1.8 angle/step
                  M906 E800 ; set extruder motor current (mA) and idle factor in per cent
                  M404 N1.75 D0.4 ; Filament and nozzle diameter
                  T0
                  ; Custom settings
                  ; Pressure Advance
                  M593 F43.48
                  M221 D0 S100
                  M207 S0.4 F3000 Z0.00
                  M200 D1.75
                  M572 D0 S0.083
                  M912 P0 S14
                  dc42undefined chrishammundefined 2 Replies Last reply Reply Quote 0
                    @serge thanks, that error is one for @chrishamm.
                    • Sergeundefined
                      Serge @dc42
                      Thanks, i have to send him the bug ?
                        @serge said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
                        No, I have asked him to look at your post.
                          @juliann, to help me diagnose this, please can you reload the new tool board firmware, then send M308 S1 with no further parameters, and report the response.
                          juliannundefined 1 Reply Last reply Reply Quote 0
                          • juliannundefined
                            juliann @dc42
                            @dc42 said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
                            M308 S1
                            After reloaded the new 3.4b2 firmware on the toolboard the behaviour changed. The reading is not good but now the heater is active instead of faulty (and temp should be around 25C).
                            M308 S1:
                            M308 S1
                            Sensor 1 type Thermistor using pin 20.temp0, reading 7.4, last error: sensor not ready, T:500000.0 B:4723.0 C:1.20e-7 R:2200.0 L:-5 H:-9```
                            dc42undefined Sergeundefined 2 Replies Last reply Reply Quote 0
                              @juliann thanks. I am looking into it.
                              • Sergeundefined
                                Serge @juliann
                                @juliann Yes, exactly the same issue i have.
                                • Sergeundefined
                                  Serge @dc42
                                  @dc42 Same for me.
                                  And after a very long time idle, the sensor temp works around the bed sensor temp but is very unstable :
                                  Enregistrement d'écran 2021-08-03 à 17.53.47.mp4
                                  • juliannundefined
                                    juliann @Serge
                                    Yes @Serge I think you are correct, it seems we have exactly the same issue now.
                                    • Sergeundefined
                                      Serge
                                      Rolling back the toolboard firmware to 3.3, and no issue than 6° higher for the hotend than the bed sensor. But stable.
                                      • empi00undefined
                                        empi00
                                        I can confirm also a kind of this bug.
                                        Before the update I had around 29°C on the HotEnd.
                                        M308 S1 P"121.temp0" Y"thermistor" A"HotEnd" T100000 B4725 C7.06e-8
                                        empi00undefined 1 Reply Last reply Reply Quote 0
                                        • empi00undefined
                                          empi00 @empi00
                                          @empi00
                                          Flashing back to 3.3 and:
                                          PS: Using Duet3 with SBC and Toolboard 1.1
                                            dc42 administrators @empi00
                                            @empi00 I am wondering whether it just needs different calibration. Please can you:
                                            1. Send M308 S1 (assuming the tool board thermistor is Sensor 1) and record the result, in particular the H and L values.
                                            2. Send M122 B121 and record the reported VIN value
                                            3. Switch the tool board firmware to 3.4beta2.
                                            4. Send M308 S1 again, check that it reports the same H and L
                                            5. Send M122 and check tna the reported VIN value is the same as before
                                            6. Run the calibration procedure described at https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings on the tool board thermistor input. If it's tricky to do the short-circuit calibration test, just do the open-circuit calibration, which should be sufficient to correct the reading at room temperature.
                                            7. Send M308 S1 again to see the new H and L values
                                            8. Check whether the readings are now correct.
                                            I am assuming that you do not have H and L parameters in your M308 commands in config.g, so it will use the values stored in NVRAM.
                                            empi00undefined Sergeundefined jbarrosundefined 4 Replies Last reply Reply Quote 0
