After updating to 3.4.0beta2: faulty heater 1, -273.1C.
@juliann said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
What I am missing by using v3.3 on the toolboard, can I still testing input shaping or this feature is only available in 3.4?
You can still test input shaping. Very little has changed in the expansion/tool board firmware.
@dc42 Enregistrement d'écran 2021-08-03 à 17.18.41.mp4
M98 P"config.g"
Error: Operation failed (Reason: NullReferenceException in SimpleCode: Object reference not set to an instance of an object.); Configuration file for Duet 3 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 18 2021 23:17:45 GMT+0200 (heure d’été d’Europe centrale)G4 S1 ;wait for expansion boards to start
M550 P"Duet 3" ; set printer name
M669 K1 ; select CoreXY mode
G29 S1 ; Set Units to Millimeters; Drives
M569 P0.0 S0 D3 ; physical drive 0.0 goes forwards
M569 P0.1 S0 D3 ; physical drive 0.1 goes forwards
M569 P0.2 S0 D3 ; physical drive 0.2 goes forwards
M569 P0.3 S1 D3 ; physical drive 0.3 goes forwards
M569 P0.4 S1 D3 ; physical drive 0.4 goes forwards
M569 P20.0 S1 ; physical drive 20.0 goes forwards
M584 X0.4 Y0.3 Z0.0:0.1:0.2 E20.0 ; set drive mapping
M92 X80.00 Y80.00 Z800.00 E836.00 ; set steps per mm
M566 X2520.00 Y2520.00 Z480.00 E2520.00 ; set maximum instantaneous speed changes (mm/min)old 2520 for XY
M203 X30000.00 Y30000.00 Z900.00 E3600.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z320.00 E3600.00 ; set accelerations (mm/s^2)Old 3480 for XY
M906 X1600 Y1600 Z1200 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M671 X0:200:409 Y-2:407:-2 S5 ; define positions of Z leadscrews or bed levelling screws; Axis Limits
M208 X410 Y400 Z400 S0 ; set axis maxima; Endstops
M574 X1 S1 P"20.io1.in" ; configure active high endstops
M574 Y2 S1 P"io1.in" ; configure active high endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P8 C"20.io0.in" I1 H3 F600 69000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P1000 X-27.8 Y-12 Z1.668
M556 S280 X-1.25 Y0 Z0 ; set orthogonal axis compensation parameters; set Z probe trigger value, offset and trigger height
M557 X15:380 Y15:380 S35 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed" ; configure sensor 0 as thermistor on pin temp0
M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
M307 H0 B0 R0.706 C344.2 D4.98 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 A"Hotend" ; configure sensor 1 as thermistor on pin 20.temp0
M950 H1 C"20.out0" T1 ; create nozzle heater output on 20.out0 and map it to sensor 1
M307 H1 B0 R5.925 C228.4:147.2 D9.34 S0.50 V24.0 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S285 ; set temperature limit for heater 1 to 285C; Fans
M950 F1 C"20.out2" Q500 ; create fan 0 on pin 20.out2 and set its frequency
M106 P1 C"Hotend Fan" S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
M950 F0 C"20.out1" Q500 ; create fan 1 on pin 20.out1 and set its frequency
M106 P0 C"Layer Fan" S0 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M955 P20.0 I24 S60 R10 ; Configure Accelerometer
M956 P20.0 S60 A0 ; Collect accelerometer data and write to file; EVA 2 / BMG / E3D V6
M92 E830 ; set extruder steps per mm, 1.8 angle/step
M906 E800 ; set extruder motor current (mA) and idle factor in per cent
M404 N1.75 D0.4 ; Filament and nozzle diameter
T0; Custom settings
; Pressure Advance
M593 F43.48
M221 D0 S100
M207 S0.4 F3000 Z0.00
M200 D1.75
M572 D0 S0.083
M912 P0 S14; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@serge thanks, that error is one for @chrishamm.
Thanks, i have to send him the bug ? -
@serge said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
Thanks, i have to send him the bug ?No, I have asked him to look at your post.
@juliann, to help me diagnose this, please can you reload the new tool board firmware, then send M308 S1 with no further parameters, and report the response.
@dc42 said in After updating to 3.4.0beta2: faulty heater 1, -273.1C.:
M308 S1
After reloaded the new 3.4b2 firmware on the toolboard the behaviour changed. The reading is not good but now the heater is active instead of faulty (and temp should be around 25C).
M308 S1:
M308 S1 Sensor 1 type Thermistor using pin 20.temp0, reading 7.4, last error: sensor not ready, T:500000.0 B:4723.0 C:1.20e-7 R:2200.0 L:-5 H:-9``` -
@juliann thanks. I am looking into it.
@juliann Yes, exactly the same issue i have.
@dc42 Same for me.
And after a very long time idle, the sensor temp works around the bed sensor temp but is very unstable :
Yes @Serge I think you are correct, it seems we have exactly the same issue now.
Rolling back the toolboard firmware to 3.3, and no issue than 6° higher for the hotend than the bed sensor. But stable.
@empi00 I am wondering whether it just needs different calibration. Please can you:
- Send M308 S1 (assuming the tool board thermistor is Sensor 1) and record the result, in particular the H and L values.
- Send M122 B121 and record the reported VIN value
- Switch the tool board firmware to 3.4beta2.
- Send M308 S1 again, check that it reports the same H and L
- Send M122 and check tna the reported VIN value is the same as before
- Run the calibration procedure described at https://duet3d.dozuki.com/Wiki/Calibrating_thermistor_and_PT1000_readings on the tool board thermistor input. If it's tricky to do the short-circuit calibration test, just do the open-circuit calibration, which should be sufficient to correct the reading at room temperature.
- Send M308 S1 again to see the new H and L values
- Check whether the readings are now correct.
I am assuming that you do not have H and L parameters in your M308 commands in config.g, so it will use the values stored in NVRAM.
If you manage to reproduce this, please open a Linux console and send
journalctl -u duetcontrolserver -e --no-pager
and send me the output. It should contain the stack trace of the underlying exception, which should make it easier for me to fix. -
Hey guys.
So i am not an expert in programing stuff.I change a lot on my modified Ender5 in the last week.
Try different hotends (THC-01 , Cyclops+ original , Cyclops fake , 2 in 1 out)
Update to capacitive sensor........Everytime i got bad printing results. Lot of stinging and so on.
Today, i swop back to firmware 3.3.0 and print the same stinging test what was on the sd cart.
I am supprised!
Have a look on the picture yourself.
I do not know if it has to do with the firmware...
But i only change the firmware.Don´t understand me wrong, i like duet products, and this should only help you.
@uneumann36 hanks for your feedback. It would be helpful if you could run the tests that I asked for in my response to @empi00, which is about 3 posts before this one.
I will.
But i can only do it wednessday earlierst, as I am out with my family the next days!
