Cant Connect Maestro
@erickindi still worth upgrading.
If you can use YAT, use fallback procedure 1 to upgrade, taking note that you should go to 2.05.1, then 3.0 and then 3.3 -
@jay_s_uk
It is reporting that the "iap4s.bin" is not found, I tried renaming the "DuetMaestroIAP.bin" file to "iap4s.bin" but it still reports the same old firmware with the M115 commmand.. Is this the correct procedure? Thanks -
@erickindi no. which firmware are you trying to upgrade from/to?
still at 2.01beta1? -
@jay_s_uk From 2.01beta1(RTOS) to 3.0
@erickindi i believe its this one https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/DuetMaestroIAP.bin
@jay_s_uk do I have to rename to "iap4s.bin" in the sys folder? I tried both ways, and it does not update..
Why it is important to update to 3.0 now?
Thanks again -
@erickindi sorry, i gave you the wrong one
go for this one https://github.com/Duet3D/RepRapFirmware/releases/download/2.0/iap4s.bin
there have been lots of updates to improve the ethernet so its worth making sure you are running up to date firmware first -
@jay_s_uk Thankyou so much! Now it is updated to the 3.3 firmware! (3.0 and then to 3.3).
But I get the same error connecting to the web control..The command line I use:
SENDING:M552 S1 P192.168.1.158
Network running, IP address = 192.168.1.158
M552
SENDING:M552
Network is enabled, configured IP address: 192.168.1.158, actual IP address: 192.168.1.158But there is nothing in the 192.168.1.158 Ip
If I change to 0.0.0.0 it is the same thing... -
@erickindi what OS are you on?
Can you try and load the page using an incognito tab?
Can you also try adding the subnet mask and gateway? -
@jay_s_uk Im on Windows using chrome. But I am using my Duet Ethernet in my other printer with no problems.
@jay_s_uk Thank you so much for your help!!!
For some reason, when I conected to another router, it worked!!
