    Variable "already exists"
    Gcode meta commands
    1.3k
    • DonStaufferundefined
      DonStauffer @fcwilt
      @fcwilt First thing I just copied the entire SD card to my raid array. Then I renamed the files. Now I'll see what happens.
        DonStauffer @fcwilt
        @fcwilt OK, that worked. And the last couple changes I made were to add and then delete a space to the file, so essentially, the backup has everything. Wow. That shouldn't have happened.
          DonStauffer @fcwilt
          @fcwilt Anyhow, nice little bit of drama. Thanks for keeping me grounded there for a bit.
          As to variables, I may just put in the test because it won't clutter the globals, and the whole purpose for them being in the file was that you could change them as needed. They function like constants in a normal language. So making them global would be counterproductive for this purpose.
          But I wonder if this is by design. I doubt it.
          • fcwiltundefined
            fcwilt @DonStauffer
            @donstauffer said in Variable "already exists":
            If you are going to do the tests it might be easier to read if you had a section where you just tested and created the variables if needed and another section where you just set them knowing they either already exist OR they have just been created by the section above.
            Otherwise you would have a bunch of if/else where the needed value appeared twice, once for the creation and once for the setting.
            DonStaufferundefined 1 Reply Last reply Reply Quote 0
            • kb58undefined
              kb58 @DonStauffer
              @fcwilt The files are there, including config.g, which shows zero bytes!
              Interesting... I had this exact thing happen several weeks ago and am pretty sure it was due to a corrupted write. I had to delete config.g and renamed config.bak as config.g. The other way was to remove the SD drive and fix it in the PC - I always keep duplicates of the SD files on the PC for just this sort of reason.
              Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
                DonStauffer @fcwilt
                @fcwilt I see what you mean. Create them with dummy values like zero, if they need to be created. That way the values only need to be tracked in one place. Not sure if you can create them without assigning a value. The documentation seems to say not.
                  Phaedrux Moderator @DonStauffer
                  What I've been doing is editing config.g - just putting in a space, deleting it, then saving it, and telling it yes to restart the board.
                  Kind of a weird way to do it. Hitting the emergency stop button in DWC. Or sending M999 for a soft reset would be cleaner.
                  How often do you think you've done that to reset the board? I wonder if you've triggered a bug that fails to write the config.g.
                    DonStauffer @Phaedrux
                    @phaedrux Maybe a half dozen times a day. Usually I turn the machine off over night if I'm not printing anything long. I didn't know about M999 and I sort of thought emergency stop just kind of hung the machine and I had to turn it off anyway. Not sure. I haven't done it much.
                      The emergency stop button basically runs M112 to do a full halt, and then resets the firmware with M999.
                      https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M112_Emergency_Stop
                      https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M999_Restart
                        Was there anything unique to the time that it erased the config.g file?
                        For the sake of completeness, could you share the config.g and the results of M122?
                        DonStaufferundefined 2 Replies Last reply Reply Quote 0
                          @phaedrux No, nothing unique I can think of. Just that message. I've attached config.g.bak to this message. It's the latest version of the file that I have. Its contents should be precisely what was in the file when it happened.
                          [0_1628740265183_config.g.bak](Uploading 100%)
                            @phaedrux
                            8/11/2021, 10:52:45 PM M122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
                            Board ID: 08DGM-9T6BU-FG3SN-6JKD0-3S06Q-9AY7D
                            Used output buffers: 3 of 24 (15 max)
                            Static ram: 23876
                            Dynamic ram: 76604 of which 0 recycled
                            Never used RAM 11080, free system stack 188 words
                            Tasks: NETWORK(ready,10.1%,246) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,340) DUEX(notifyWait,0.0%,24) MAIN(running,83.8%,442) IDLE(ready,6.0%,29), total 100.0%
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:00:12 ago, cause: software
                            Last software reset at 2021-08-11 22:52, reason: User, GCodes spinning, available RAM 10856, slot 0
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Step timer max interval 0
                            MCU temperature: min 46.2, current 46.7, max 47.0
                            Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/32/0, gc cycles 0
                            Driver 0: position 0, standstill, SG min/max not available
                            Driver 1: position 0, standstill, SG min/max not available
                            Driver 2: position 0, standstill, SG min/max not available
                            Driver 3: position 0, standstill, SG min/max not available
                            Driver 4: position 0, standstill, SG min/max not available
                            Driver 5: position 0, standstill, SG min/max not available
                            Driver 6: position 0, standstill, SG min/max not available
                            Driver 7: position 0, standstill, SG min/max not available
                            Driver 8: position 0, standstill, SG min/max not available
                            Driver 9: position 0, standstill, SG min/max not available
                            Driver 10: position 0
                            Driver 11: position 0
                            Date/time: 2021-08-11 22:52:44
                            Cache data hit count 470797477
                            Slowest loop: 4.44ms; fastest: 0.17ms
                            === Storage ===
                            Free file entries: 10
                            SD card longest read time 0.9ms, write time 0.0ms, max retries 0
                            === MainDDARing ===
                            === AuxDDARing ===
                            Heater 1 is on, I-accum = 0.0
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                            === DueX ===
                            Read count 1, 4.85 reads/min
                            === Network ===
                            Slowest loop: 151.71ms; fastest: 0.00ms
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is active
                              WiFi firmware version 1.26
                              WiFi MAC address 84:f3:eb:83:47:be
                              WiFi Vcc 3.36, reset reason Power up
                              WiFi flash size 4194304, free heap 26496
                              WiFi IP address 192.168.1.130
                              WiFi signal strength -43dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Clock register 00002002
                              Socket states: 4 0 0 0 0 0 0 0
                            • fcwiltundefined
                              fcwilt @DonStauffer
                              You would need to assign some placeholding value, like zero, I'm sure you could determine suitable values in each case.
                                dc42 administrators @DonStauffer
                                I have my slicer set to insert a few variable definitions (var, not global) into the gcode files it produces. Works fine, except if I then upload and try to print another file without first restarting the duet, I get this "already exists" error, even though the original file completed and I started another.
                                Is that the way it's supposed to work?
                                I agree, it would make sense to treat local variables created in a print file the same as variables created in a macro file and remove them when the file completes or is cancelled. I will add a work item to fix this.
                                  DonStauffer @fcwilt
                                  @fcwilt The problem with conditionally defining local variables is:
                                  "The scope of a local name is the remainder of the block in which it is declared."
                                  So, this will produce "unknown variable":
                                  if !exists(var.xxx)
                                  	var xxx=0
                                  set var.xxx=4
                                  I'm trying to think of a workaround I can use right now, besides just making them globals.
                                  • fcwiltundefined
                                    fcwilt @DonStauffer
                                    if !exists(var.xxx)
                                    	var xxx=0
                                    set var.xxx=4
                                    Well that is not good news.
                                    This my be a problem only @dc42 can solve.
                                      DonStauffer @fcwilt
                                      @fcwilt I've just been doing an M999 between jobs for now.
