Trouble Declaring Global Var
Gcode meta commands
declare global help
    printernoodle
    How do you define a global variable?
    I have tried entering
    global status=true
    in the console
    And then the web interface just goes into a non stop connect disconnect loop.
    Tried the same with
    global status=1
    even tried putting this declaration right into gonfig.g
    That just put the entire system into the same connection connect disconnect loop regardless of reboot.
    I've been struggling with this for a bit now....
    cant get a global variable created...
    What am I not doing here?
    undefined 1 Reply Last reply 16 Aug 2021, 03:06 Reply Quote 0
      fcwilt @printernoodle
      @printernoodle
      What firmware version are you using?
      What board are you using?
        printernoodle
        @fcwilt
        sorry it's 3.3 rc2
        duet 2 wifi
        undefined 1 Reply Last reply 16 Aug 2021, 03:28 Reply Quote 0
          @printernoodle
          Well the release version of 3.3 is out and it works fine with global variables.
          I suggest you update and try then.
          Have you tried any other variable names?
          undefined 3 Replies Last reply 16 Aug 2021, 03:30 Reply Quote 1
            printernoodle @fcwilt
            @fcwilt
            yes I've tried "global derack" "global magprobe_status" "global qgl"
            all start some weird connection loop on the DWC
              @fcwilt
              and then
              Over and over again.....frozen on boot up
              I will try the new release.
                @fcwilt
                going to the release version of 3.3 seems to have fixed it.
                Thank you very much indeed!!
                2 out of 7
