    Sent Gcode commands not going away in DWC console
    Duet Web Control
    492
    • code7undefined
      code7
      Is there a setting or something that I can do differently when sending a gcode command through the DWC console to have it disappear after pressing <Enter>?
      Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
      fcwiltundefined code7undefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @code7
        @code7
        Why do you wish that?
        I find it very useful to be able to execute the same command many times just by hitting the Enter key.
        code7undefined 1 Reply Last reply Reply Quote 0
        • code7undefined
          code7 @fcwilt
          @fcwilt
          I seldom send the same gcode command twice in a row. It would be cool if you could use the up arrow (like in DOS and other programs) to populate the previous command if you want to run it again.
          • fcwiltundefined
            fcwilt @code7
            @code7 said in Sent Gcode commands not going away in DWC console:
            @fcwilt
            Well the up/dn cursor keys being up the list of previous commands and you can select the one to execute.
            • code7undefined
              code7 @fcwilt
              @fcwilt said in Sent Gcode commands not going away in DWC console:
              It's usually quicker for me to just retype the command than having to scroll through a list when I'm looking at the printer.
              • fcwiltundefined
                fcwilt @code7
                True but as you type it jumps to the next match in the list.
                • code7undefined
                  code7 @code7
                  @fcwilt
                  @Phaedrux
                  I use the DWC console to send a lot of different commands. Is there anyone else that thinks this suggested update above would be helpful so we don't need to delete every command we send prior to sending a new command?
                  • fcwiltundefined
                    fcwilt @code7
                    @fcwilt
                    @Phaedrux
                    There is no need to delete old commands. Why do you think that is the case?
                      I wouldn't mind if it had an option to behave more like a command line terminal where after you press enter the command is sent and disappears and then you can press up arrow to cycle through previous command history. That's just my muscle memory. I do find it annoying to have to constantly delete the previous command to type something new.
                      • fcwiltundefined
                        fcwilt @Phaedrux
                        @phaedrux said in Sent Gcode commands not going away in DWC console:
                        I am seeing something different in firmware 3.3.
                        When I click on the command line of the DWC Console any existing command is selected and any new command typed in replaces what was there.
                        • code7undefined
                          code7
                          @Phaedrux
                          When in click on the command line of the DWC Console any existing command is selected and any new command typed in replaces what was there.
                          This only happens the first time you click into the command console. If you send a second command in the console it does not behave this way. I vote with Phaedrux.
                          "I wouldn't mind if it had an option to behave more like a command line terminal where after you press enter the command is sent and disappears and then you can press up arrow to cycle through previous command history. That's just my muscle memory. I do find it annoying to have to constantly delete the previous command to type something new."
                          • fcwiltundefined
                            fcwilt @code7
                            @code7
                            Interesting you should mention "muscle memory".
                            When you pointed out the behavior that was different from mine I paid more attention to what I was doing.
                            Tab then Shift-Tab
                            It had become so automatic I was no longer aware I was doing it.
                            The mind is a interesting thing.
