Z limits not working when tool Z offset stablished (G30 S-2)
We have Z axis limited to Z min = 0; Z max = 100.
M208 X-200:200 Y-125:125 Z0:100
But when we select a tool, and probe it using a switch (see command below)
G30 K1 S-2; select the switch probe, probe, and stablish current tool offset The position is stablished correctly, but the machine allows to move to negative Z positions with the tool selected.
How can we make it work?
Can you post the rest of your configs? Firmware version?
@phaedrux
Sorry for the delay, I've been preparing a simplified version of the config, that results in the same problem.The problem comes when stablishing the Z offset of the tool. We have 3 diffent vertical axis (Z,U,V), but we always map the current tool to Z (see free1.g and post0.g).
The are other things that we need to work on when changing a tool, but the problem we need to solve is that when stablishing a tool Z offset. the system allow negative coordinates...
The firmware version is 3.4.beta2, each tool is driven by a 1LC, base board is a 6HD and 1XD for each servo axis.
config.g
; customPrinter firmware config file ; executed on start-up ; ; ;################################ GENERAL SETTINGS ################################ M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"M3dimaker2" ; set printer name G4 S3 ; wait for expansion boards to start M669 K0 S100 ; cartesian kinematics and segments per second ;######################### AXIS BOARD DRIVERS DECLARATIONS ######################### M569 P40.0 S1 ; physical drive 40 goes forwards X M569 P41.0 S0 ; physical drive 41 goes forwards Y1 M569 P42.0 S0 ; physical drive 42 goes forwards Y2 M569 P43.0 S0 ; physical drive 43 goes backwards Z1 (Z) M569 P44.0 S0 ; physical drive 44 goes backwards Z2 (U) M569 P45.0 S0 ; physical drive 45 goes backwards Z3 (V) M569 P20.0 S1 ; physical drive 20 goes forwards E0 M569 P21.0 S1 ; physical drive 21 goes forwards E1 M569 P22.0 S1 ; physical drive 22 goes forwards E2 ; ############################## DRIVER PARAMETERS SETTINGS ############################## ; Axis configuration M584 X40.0 Y41.0:42.0 Z43.0 U44.0 V45.0 ; axis drive mapping M350 X1 Y1 V1 Z1 U1 V1 I1 ; configure axis microstepping with interpolation M92 X150.53 Y150.53 Z100.12 U100.12 V100.12 ; axis steps per mm M566 X900.00 Y900.00 Z500.00 U500.0 V500.0 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z12000.00 U12000.00 V12000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z500.00 U500.00 V500.00 ; set accelerations (mm/s^2) ; Extruders configuration M584 E20.0:21.0:22.0 ; extruders drive mapping M350 E16:16:16 I1 ; configure extruders microstepping with interpolation M92 E409.00:42.00:420.00; extruders steps per mm M566 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 E1200.00:1200.00:1200.00 ; set maximum speeds (mm/min) M201 E250.00:250.00:250.00 ; set accelerations (mm/s^2) M906 E1000:1000:1000 I30 ; set motor currents (mA) and timeout time ;################################# Z PROBE 0 CONFIG ################################# M950 S0 C"out4" ; create servo pin 0 for solenoid on Out4 M558 P8 C"io3.in" H1 R6.5 F1200 T3000 ; set Z probe type and the dive height + speeds G31 X0 Y0 Z5 ; set Z probe trigger value, offset and trigger height ;################################ TOOL Z PROBE CONFIG ################################ ; Tool offset pin declaration here ; This probe will measure each tool offset M558 K1 P8 C"io1.in" H1 R6.5 F1000 T2000; declare probe 1 as type 8 G31 K1 P1000 X0 Y-120 Z-1.3 ; When probe 1 value = 1000, actual position as X0, Y-120, Z-1.3 ; #################################### MESH GRID #################################### M557 X-100:100 Y-125:125 S20 ; define mesh grid M84 S30 ; Disable motor idle current reduction ;################################## AXIS LIMITS ################################## M208 X-200:200 Y-125:125 Z0:100 U0:100 V0:100 ; set axis minima and maxima ;M208 X-200:200 Y-125:125 ;M208 Z0 U0 V0 S1 ;################################# AXIS ENDSTOPS ################################# M574 X1 S1 P"!40.io0.in" ; configure active-high endstop for low end on X via pin 40.io0.in M574 Y1 S1 P"!41.io0.in" ; configure active-high endstop for low end on Y via pin 41.io0.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z M574 U2 S1 P"!44.io0.in" ; configure active-high endstop for high end on U via pin 44.io0.in M574 V2 S1 P"!45.io0.in" ; configure active-high endstop for high end on V via pin 45.io0.in ;######################### PRINTER HEATERS DECLARATIONS ######################### ; FDM heater M308 S2 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8 M950 H2 C"20.out0" T2 M307 H2 B0 R2.131 C224.9 D4.61 S1.00 V23.6 M143 H2 S280 ; GEL heater M308 S3 P"21.temp0" Y"thermistor" T100000 B4725 C7.06e-8 M950 H3 C"21.out0" T3 M307 H3 B0 R0.511 C181.9 D6.18 S1.00 V23.8 M143 H3 S140 ; POWDER heater M308 S4 P"22.temp0" Y"thermistor" T100000 B4725 C7.06e-8 M950 H4 C"22.out0" T4 M307 H4 B0 R1.622 C246.4 D5.15 S1.00 V23.9 M143 H4 S175 ; Bed heater M308 S0 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 M950 H0 C"out1" T0 M307 H0 B0 R0.419 C401.2 D2.65 S1.00 V0 M140 H0 M143 H0 S100 ; Syringe preheater M308 S1 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 M950 H1 C"out0" T1 M307 H1 B0 R0.302 C822.1 D3.84 S1.00 V24.0 M141 H1 M143 H1 S130 ;########################## PRINTER FANS DECLARATIONS ########################## ; No fans yet ;######################### PRINTER TOOL DECLARATIONS ########################## ; FDM TOOL M563 P0 S"FDM" D0 H2 F0 G10 P0 X-52 Y-58 ; set x,y offsets G10 P0 R0 S0 ; set standby temperatures ; GEL TOOL M563 P1 S"GEL" D1 H3 F0 G10 P1 X0 Y0 ; set x,y offsets G10 P1 R0 S0 ; set standby temperatures M591 D1 P1 C"21.io0.in" S1 ; filament monitor for GEL printhead, enable to call filament-error.g when pin detected ; POWDER TOOL M563 P2 S"POWDER" D2 H4 F0 G10 P2 X0 Y0 ; set x,y offsets G10 P2 R0 S0 ; set standby temperatures T-1 ; Unselect tool toolZOffset.g
; ; param.A -> tool N T{param.A} ; select the tool G90; absolute positioning G1 X0 Y-120 F1000 ; go to swith position M400 ; wait ; move Z until switch triggered ; https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe G30 K1 S-2 ; Probe 1. When triggered, set Z offset of the current tool. echo "Actual position - ", {move.axes[2].machinePosition} G92 Z-0.3 G1 H4 Z100 F800; lift after probing G1 X0 Y0 F2000; go to X0 Y0 free1.g
G91 ; relative positioning G1 Z105 F2000 ; lift U G90 ; absolute positioning M400 ; wait movement G60 S2 ; store coordinate in restore point 2 M584 Z43.0; remap Z to original axis post1.g
M584 Z44.0 ; remap U drive to Z axis
@carlosr the limits set by M208 are the allowed movement limits of the head reference point, and do not take account of tool offsets. This generally works well for X and Y limits and for the Z max limit; but I appreciate that it isn't ideal for the Z min limit.
You can change the Z min limit in the tpost#.g file. Don't forget to reset it in the tfree#.g file.
Do you mean by overwritting the M208?
If I understand correctly, the new minimum should be the previous minimum (in relation with the HRP) + tool offset.
I'mma try it out.
Thank you for your comment.
