    Duetwifi Duex5
    • Sjoerd de Haasundefined
      Sjoerd de Haas
      Good day everybody,
      got a duet wifi with a duex5 for a IDEX setup,
      got everything connected and first i don't see any duex5 when M115.
      Got a new flat cable from Duet, (old one looked damaged) and after this i could see
      the duex5 about 2 hours, now i again have the problem with the connection it seems.
      Now i'm thinking that my duex has bad connections or my duet wifi.
      Anyone who can help me, or had same issues?
      I'm getting nuts here.
        Sjoerd de Haas
        Looks like there's a bad connection with the duex5 and not every pin gets connected. so the firmware does not load the duex5 part.
        with the new cable it all worked for a few hours, but now i can't get it to work anymore.
        connectors are fitted correctly and are propper in there sockets.
          We've had a small number of instances of DueX2/DueX5 boards on which a connection between the I/O expander chip and the PCB is intermittent. I suspect that's what's happening in your case, so please ask for the DueX5 to be replaced. I'm sorry for the inconvenience this is causing you.
