how to configure magnetic filament sensor on duet 3 mini 5+
Filament Monitor
    j3dk
    I have conected my rotating magnet sensor to IO_5 on Duet3 mini 5+ but I can't find out how to set up my config.g
    ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
    ; generated by RepRapFirmware Configuration Tool v3.3.2 on Thu Sep 16 2021 12:55:16 GMT+0200 (Centraleuropæisk sommertid)
    M550 P"JK Preddy mod" ; set printer name
    M665 R261 L440 B185 H420 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S1 ; enable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0.3 S0 ; physical drive 0.3 goes backwards
    M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
    M92 X80.00 Y80.00 Z80.00 E415.00 ; set steps per mm
    M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
    M84 S30 ; Set idle timeout
    M208 Z0 S1 ; set minimum Z
    M574 X2 S1 P"^io1.in" ; configure active-high endstop for high end on X via pin ^io1.in
    M574 Y2 S1 P"^io2.in" ; configure active-high endstop for high end on Y via pin ^io2.in
    M574 Z2 S1 P"^io3.in" ; configure active-high endstop for high end on Z via pin ^io3.in
    M558 P5 R0.4 C"temp2+io4.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
    M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
    M557 R180 S20 ; define mesh grid
    M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
    M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
    M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
    M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
    M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
    M106 P2 S0.25 H-1 ; set fan 2 value. Thermostatic control is turned off
    ; Custom settings
    M591 P3 C"e0_stop" S1 ; filament monitor connected to E0_stop
    T0 ; select first tool
    what am I missing?
    Jk
    undefined 1 Reply Last reply 20 Sept 2021, 12:07 Reply Quote 0
      droftarts administrators @j3dk
      @j3dk See https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_RotatingMagnetVersion#Section_Duet_Num_3 for connecting.
      Change C"e0_stop" (which is Duet 2 pin name) to C"io[x].in" where [x] is the IO connector you have connected the sensor to.
      undefined 1 Reply Last reply 20 Sept 2021, 13:21 Reply Quote 0
        j3dk @droftarts
        @droftarts Hi there thank you for the advise. now I have figured it out putting this line in my config.g it works
        M591 D0.3 P3 C"^io5.in" S1 ; filament monitor connected to E0_stop
        Jk
        undefined 1 Reply Last reply 20 Sept 2021, 13:29 Reply Quote 0
          @j3dk said in how to configure magnetic filament sensor on duet 3 mini 5+:
          C"^io5.in"
          You shouldn't need the ^ character in the pin name, it enables the pullup resistor.
          3 out of 4
