    Errors while building RRF 3.4beta3
    Firmware developers
    918
    • JayTundefined
      JayT @dc42
      Also how does it say finished building by invoking arm-non-eabi-g++ and yet throw error about GCC path and G++ path not found?
      JayTundefined 1 Reply Last reply Reply Quote 0
      • JayTundefined
        JayT @JayT
        @jayt : And when i run build-all , it gets stuck after 62%.it takes a lot of time. it wasn't taking so much time, untill i reimported the projects. 😞
          dc42 administrators @JayT
          @jayt the only thing you need to include in your windows path is the path to the Gnu Arm Eclipse folder, so that Eclipse can find make.exe. Looks like that bit is working.
          My guess is that the "g++ not found" error is because you are trying to build DuetWiFiSocketServer or one of its dependent projects and you haven't set up the path to the Tensilica version of gcc. But you don't need to build that project.
          JayTundefined 1 Reply Last reply Reply Quote 1
          • JayTundefined
            JayT @dc42
            @dc42 :
            After iterating whole process again, I now receive following type of error ( that says on element: makefile, in folder RepRapfirmware/Duet3_debug, line 110):
            Any idea what am I missing?
            Also I remove duetwifisocket from RepRapfirmware-> build list
              @jayt it looks like just the post build step failed. There is probably a more detailed message in the Console tab.
              JayTundefined 2 Replies Last reply Reply Quote 1
              • JayTundefined
                JayT @dc42
                @dc42 :
                CRC32appender not found - is the error. I changed the path as stated in the thread: "Can't build RRF 3.3"
                I have restarted "Build all". But do I have to run "Build ALL" always ? and I feel its slower than the last time i tried build.
                Shall confirm if the build completes by next reply.
                • JayTundefined
                  JayT @dc42
                  @dc42 :
                  I receive following error on CRC32appender not found when invoked by some scripts sh.
                  my user Path variable includes this path:
                  "C:\Users\User3D\eclipse-workspace\Firmware\RepRapFirmware\Tools\crc32appender\win-x86_64"
                  What else shall i do to fix this ?
                  • JayTundefined
                    JayT @JayT
                    @jayt : This issue is now resolved.
                    I used the suggestion from the thread: https://forum.duet3d.com/topic/12275/crc32appender-now-needed-for-rrf/16.
                    Placed crc32appender in the GNU arm.... tools\bin folder.
                    this worked!
                    (Somehow, eclipse is not able to fetch it from $PATH- based settings.)
                    @dc42 @jay_s_uk : thank you for the suggestions & help.
                    can you tell me if any settings needed to build only reprap folder instead of building all projects again, if we change only one project file ?
                      @jayt you can build just the RRF project if the other projects do not change.
                      • JayTundefined
                        JayT @dc42
                        @dc42 ok great.
                        Thanks. you can close the thread as resolved.
