    Setting up to resume a print after a power failure
    1.8k
    • Renatundefined
      Renat
      I try this function and cant find file sys/resurrect.g on SD card.
      i Seach here:
      https://yadi.sk/i/QTIQ2zrk3MWJKi
      I make all as wrote here: https://duet3d.com/wiki/Setting_up_to_resume_a_print_after_a_power_failure
      in config.g
      ;Setting up to resume a print after a power failure
      ; For 20V power
      M911 S16.0:17.5:19.5 // auto-pause at 17,5V, then either stop at 16V or auto-resume at 19.5V
      powerfail.g
      G91
      G1 Z2 F2400
      M83
      G1 E-2 F3600
      powerrestore.g
      M83
      G1 E2.5 F600
      resurrect-prologue.g
      M116
      G28
      M83
      G1 E2.5 F600
      What can I do to make the function work?
      • Renatundefined
        Renat
        Firmware Name: RepRapFirmware for Duet
        Firmware Electronics: Duet 0.85
        Firmware Version: 1.19+5 (2017-08-30)
        Web Interface Version: 1.19
          If the power voltage drops too quickly when power is removed, then the Duet may not have enough power to create the resurrect.g file. It depends on how large the capacitors are on the output of your power supply.
          If your PSU voltage is nominally 20V then you can test the function by sending e.g. M911 S16.0:21.0:22.0 to temporarily increase the voltage thresholds.
          • Renatundefined
            Renat
            If i set M911 S16.0:21.0:22.0 and my voltage 20, then auto-pause and auto-resume will be off, and only save ressurect file will be active and start when voltage drops to 16V.
            Do I understand correctly?
              No, the pause and file save will occur at 21V.
              • Renatundefined
                Renat
                But my voltage only 20V, it never be 21V.
                  That's why increasing the threshold to 21V during a print should cause an immediate pause and creation of resurrect.g.
                  • Renatundefined
                    Renat
                    I can't understand 🙂
                    I Have the maximum voltage at the power supply 20 volts. Where there will take 21 volts?
                      Starting a print and then setting the the threshold temporarily to a voltage higher than your PSU voltage is a way of triggering the power down functionality, to check that it is working.
