Solved Resume from pause doesn't respect previous feederate.
@fcwilt M203 is my rapids speed. When I use G0 to call a move at max speed, that's the speed it runs at. M202 is not implemented in the firmware. G1 and G0 are modal, meaning you only have to have one line with G0/G1 and then every following line can have just coordinates to go to, just like the F parameter. In the 3d printer world, modal is called sticky I believe. So either my problem is that the lines after resume are treated as a G0, because they don't have a G command at the start of the line, or the F parameter is lost and the max is used. Either way, the firmware shouldn't behave this way, especially since the G1 R1 Z0 F75 should have both the G1 and the F75 held over as modal/sticky
Got it.
To see if the behavior is related to G0 could you, as a test, code pause and resume with only G1, using the F parameter to obtain G0 speed?
And that M202 was a typo - it should have been M220.
@zakm0n there was an issue with this in SBC mode in previous 3.4 betas that was fixed in the latest beta, if you are running SBC mode and an earlier beta of 3.4 please can you upgrade to 3.4b5 and see if the problem is fixed
@zakm0n the move back to the original location from the place you moved the tool to in pause.g will be at a default speed; but when it resumes the job, it should go at the original speed it was using when the job was paused. Is that not happening?
@dc42 No, it's not. It's resuming at top speed in the cut. Here is a snippet of the code I'm running.
G55 M8 M3 S6000 G00 Z20 G00 X13.0734 Y315.6128 G00 Z-5.08 G01 Z-7.62 F125 X13.0607 Y312.7553 X13.8151 Y312.8518 Z-7.6327 X14.5161 Y313.1464 Z-7.6454 X15.1155 Y313.6138 Z-7.6606 X15.5702 Y314.2234 Z-7.6733 X15.8496 Y314.9295 Z-7.686 X15.9309 Y315.6864 Z-7.6987 X15.8115 Y316.4357 Z-7.7114 X15.4965 Y317.1292 Z-7.7267 X15.0114 Y317.7134 Z-7.7394 X14.3891 Y318.1502 Z-7.7521 X13.6728 Y318.4068 Z-7.7648 X12.9159 Y318.4652 Z-7.78 X12.1691 Y318.323 Z-7.7927 X11.4859 Y317.9877 Z-7.8054 X10.9144 Y317.4848 Z-7.8181 X10.4978 Y316.8498 Z-7.8308 X10.2641 Y316.1259 Z-7.8461 X10.2286 Y315.3664 Z-7.8588 X10.3937 Y314.6247 Z-7.8715 X10.7493 Y313.9516 Z-7.8842 X11.27 Y313.3979 Z-7.8969 X11.9177 Y313.0017 Z-7.9121 X12.6467 Y312.7883 Z-7.9248 X13.0607 Y312.7553 Z-7.9375
@zakm0n Does a final
G1 R1
at the end of the file fix it? -
@chrishamm like at the end of resume? To be clear, this is not the entire file, just the first couple lines.
@zakm0n remove the G60 S1 command from pause.g. I think that command is causing the issue.
@dc42 spot on. It does exactly what I expect with that removed.
