    Flood of virus warnings when connecting to Duet Wifi Hotspot
    Duet Web Control
    • Unfoldundefined
      Unfold
      I have a Vormvrij Lutum ceramic 3d printer in my studio that uses a Duet 2 Wifi board running Firmware 3.2.2. When I connect my Mac to the Duet Wifi Hotspot I start seeing a flood of 'Possible virus attack' errors in console of the web interface and on the 3D printer build in touchscreen. All the errors seem to be related to ocsp traffic from my Mac.
      I found these two topics referencing the same issue but there it is mentioned that this issue should have been solved in firmware v3.1.1?:
      Virus warning message?
      DuetWifi-error: filename too long
      I tried blocking traffic to ocsp servers using Little Snitch and also all outgoing connections from the trust & ocspd processes which seem to generate that traffic but did not solve anything.
      I'm also not running any AV software.
      What else can I try?
      T3P3Tonyundefined dc42undefined 2 Replies Last reply Reply Quote 0
        T3P3Tony administrators @Unfold
        @unfold my guess would be the formatting of the oscp request is different enough from the Kapersky AV one that its not suppressed, although @dc42 will need to confirm that.
          dc42 administrators @Unfold
          @unfold RRF already makes an exception for requests for files with very long names that start with "/ocsp" but in your case it appears that there is no leading "/". I will extend the exception to handle that case too in the next 3.4beta release.
          Unfoldundefined 1 Reply Last reply Reply Quote 2
          • Unfoldundefined
            Unfold @dc42
            @dc42 thanks!
            dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
              @unfold this should be fixed in the unofficial 3.4.0beta5+1 build at https://www.dropbox.com/sh/xeu30go894p9xbs/AAB5U66SH4wbjKIcX0snUbKxa?dl=0. As you are currently running RRF 3.2.2, before using it you would need to read and understand the upgrade notes for both 3.3 and the 3.4beta releases, and make any necessary changes to configuration and homing files.
                @unfold further to what @dc42 says I recommend upgrading to 3.3 first and then to 3.4b5 (including 3.4b5 DWC, before then going to the build david has linked.
