    Z end stop errors posted during auto bed compensation
    • TimVukmanundefined
      TimVukman
      Hi:
      Cartesian Frame
      Mechanical limit switches
      HomeX works properly
      HomeY works properly
      HomeZ works properly
      HomeAll works properly
      When I run the auto bed compensation, I get error messages popping up that say that
      "the Z probe was not triggered during probing move"
      and the utility fails.
      At each probe point, I see the light on the main board turn on for the Z end stop indicating that it has triggered.
      Is there a way to see the gcode that is executing during the auto bed compensation run?
      I don't understand why it is failing, or not registering the z end stop triggering except to observe that the z end stop light goes out between probe points which I think it should (and which matches the error message), or is the z end stop supposed to be triggered throughout the probing duration and how do I make that happen without editing the auto bed compensation code?
      Thanks
      Tim
      • number40fanundefined
        number40fan
        If you have recently updated, make sure deploy and retract probe folders have been deleted.
        Then post your config and bed files.
          TimVukman
          Hi:
          Deploy and retract have been deleted.
          Bed
          [c]
          ; bed.g
          ; generated by RepRapFirmware Configuration Tool on Fri Sep 08 2017 10:03:01 GMT-0400 (Eastern Daylight Time)
          ; Clear any bed transform
          M561
          ; Home all axes
          G28
          ; Probe the bed at 5 points
          G30 P0 X25 Y25 H0 Z-99999
          G30 P1 X25 Y175 H0 Z-99999
          G30 P2 X200 Y175 H0 Z-99999
          G30 P3 X200 Y25 H0 Z-99999
          G30 P4 X140 Y100 H0 Z-99999 S
          [/c]
          Config
          [c]
          ; Configuration file for Duet WiFi (firmware version 1.17)
          M111 S0 ; Debugging off
          G21 ; Work in millimetres
          G90 ; Send absolute coordinates…
          M555 P2 ; Set firmware compatibility to look like Marlin
          M208 X210 Y280 Z180 S0 ; Set axis maxima
          M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
          M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
          G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
          M557 X25:175 Y25:175 S20 ; Define mesh grid
          M569 P0 S0 ; Drive 0 goes backwards
          M569 P1 S0 ; Drive 1 goes backwards
          M350 X128 Y128 Z128 E16 I0 ; Configure microstepping without interpolation
          M92 X640 Y640 Z3200 E100 ; Set steps per mm
          M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
          M203 X12000 Y12000 Z1200 E3000 ; Set maximum speeds (mm/min)
          M201 X1000 Y1000 Z100 E5000 ; Set accelerations (mm/s^2)
          M906 X855 Y855 Z855 E855 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M143 S260 ; Set maximum heater temperature to 260C
          M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4725 C0 R4700 ; Set thermistor + ADC parameters for heater 1
          M563 P1 D0 H1 ; Define tool 1
          G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
          G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
          M550 PTevo Tarantula ; Set machine name
          M552 S1 ; Enable network
          ; Access point is configured manually via M587 by the user
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
          T1 ; Select first tool
          [/c]
          I think I am going to have to learn a lot more about G-Code
          Thanks
          Tim
            number40fan
            What are you using for a probe? You don't have anything in your M558 for it.
              TimVukman
              Well. that might be causing my issue. I don't have a probe. I had an SN04 from my Tevo Tarantula, but I didn't want to modify the Duet to use it on this board. I have ordered one of DC42s probes, but I don't have it yet. All I have is the Z limit switch which I had hoped would allow me to print while I was waiting for the probe to arrive.
              I haven't managed to get my first print done yet.
              Can I just comment out the M558 for now? Will it then use my z limit switch, or will it just fail?
              Thanks
              Tim
                number40fan
                Just don't run the bed compensation.
                  TimVukman
                  Ok, Thanks very much.
                  Now I can work setting up the 1st layer and so on.
