    height map error
    Beta Firmware
    • kordrisundefined
      kordris
      Im getting this error after updating my Pi 4 though the sudo update etc.. But Im not to sure what I need to do to fix this one. I have read though all the documents on the G29 commands. There's nothing about change in the command. So not sure why I'm getting this error. I need to get this fixed so I can use the mesh like i'm use to. I use the G29 S1 in my Homeall.g and also in my macro for my start gcode. I have the heightmap.cvs is in my main directory but not sure if it needs to be moved or needs to be in other places now.
      error: g29: cannot use height map on local sd card when sbc interface is used
      T3P3Tonyundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        T3P3Tony administrators @kordris
        @kordris what version of RRF and DSF do you have reported?
        • chrishammundefined
          chrishamm administrators @kordris
          @kordris If you are on the unstable package feed, try running M997. It sounds like you are still using an old RRF version.
          Duet software engineer
          kordrisundefined 1 Reply Last reply Reply Quote 0
          • kordrisundefined
            kordris @chrishamm
            @chrishamm This is what is says in my system page. Not sure if this is what your after. Also I did try to run that command you said. It give a update display popup. Then it went away. Not sure if that fix the issue or not. But will try here in a few. That seems to fix the error. But now I can get it to run a G29 or anything from the menu on the compensation and calibration menu.
            Board: Duet 3 MB6HC (MB6HC)
            DSF Version: 3.4-b6
            Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.0beta6 (2021-11-06)
            • kordrisundefined
              kordris
              I got it fixed so the M997 worked great. Not sure what it actually did so if you can tell me so I know for next time. But when I was trying to figure out the heightmap issue I tried putting a mesh.g file in the files. So that was causing the mesh from from working. So deleted the file and works fine now. Thank you for the help. Seems to working fine now.
