odroid sbc working with duet3 mini but not with 6hc ?
    joeko
    i got the odroid c4 running with debian buster connected to a duet3 mini but the same board doesnt work with the duet3 6hc. with duet3 mini all fine, with duet 6hc nothing...
    now i ask me what is wrong. the only different is that on the 6hc is the latest beta installed and on the mini the latest stable. on both boards i have removed the sd card. is that possible that this is the reason that i have to downgrade the 6hc to the stable and than i can connect to the sbc ?
    undefined 1 Reply Last reply 10 Nov 2021, 22:12 Reply Quote 0
      dc42 administrators @joeko
      @joeko said in odroid sbc working with duet3 mini but not with 6hc ?:
      Yes, or else upgrade the sbc to the latest unstable version of DSF.
      undefined 1 Reply Last reply 11 Nov 2021, 15:04 Reply Quote 0
        joeko @dc42
        @dc42 said in odroid sbc working with duet3 mini but not with 6hc ?:
        ok now. flashed the stable firmware on the 6hc and now it is running from the odroid sbc 🙂
        but now i have a new question.
        i use 3 z leadscrew ithe kinematic bedlevelling. i have created the bed.g
        ; bed.g
        ; generated by RepRapFirmware Configuration Tool v3.3.4 on Sat >Oct 23 2021 07:25:18 GMT+0200 (Mitteleuropäische Sommerzeit)
        ;M561 ; clear any bed transform
        ;G29 ; probe the bed and enable compensation
        G90
        echo "Bett ausrichten"
        M561
        G28
        M98 P"gantry_level.g"
        while move.calibration.initial.deviation >= 0.01
        echo "Abweichung: " ^ move.calibration.initial.deviation ^ "mm" >^ " nochmal"
        echo "Fertig Abweichung: " ^ move.calibration.initial.deviation ^ >"mm"
        echo "Drucker homen."
        G28 Z
        without sbc modus i got the displaymessage after start levelling
        "Bett ausrichten"
        now in sbc modus i dont get this message until the levelling is finised. i dont get console message until the prozes is finished.
        not on paneldue or on the browser. all messages at the same time
        undefined undefined 2 Replies Last reply 11 Nov 2021, 20:28 Reply Quote 0
          joeko
          This post is deleted!
            If you can, please upgrade your system to firmware 3.4.0beta6 via the unstable feed of the Duet3D package server, and test again. If you still have the same issue with that firmware, then this is one for @chrishamm to look at.
              chrishamm administrators @joeko
              @joeko @dc42 That's a known limitation of v3.3. v3.4 will print echo messages and code replies instantly like rrf does.
              Duet software engineer
              6 out of 6
