    Any PWM Fan not working
    2.8k
    • tommertensundefined
      tommertens
      Adding the M106 command didn't do anything unfortunately.
      • number40fanundefined
        number40fan
        F10 at the end?
          tommertens
          Yep, as below.
          M106 P0 S0.3 I0 H-1 F10 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            number40fan
            I don't have particular fan to try, but I do have a 40x40x30.
            M106 P1 H-1
            M563 P0 D0 H1 F0:1 is what I have in my config and I was able to PWM control it. Might be worth a shot.
              @tommertens:
              Yep, as below.
              You have fan 0 set at 30% PWM and fans 1 and 2 in thermostatic mode. Not a good test. Try them in non thermostatic mode at 100% speed:
              M106 P0 S1 H-1
              M106 P1 S1 H-1
              M106 P2 S1 H-1
                deckingman
                @tommertens:
                Yep, as below.
                As Tony asked, does it work if you set full on by using S1?
                If that works, then you could try S0.3 but use the B parameter to give it a blip https://duet3d.com/wiki/G-code#M106:_Fan_On
                Edit. I was typing at the same time as David
                  tommertens
                  It doesn't work with S1 either. Neither did the F0:1 line.
                    tommertens
                    Here is my config.
                    ; CoreXY sample config file for dc42 Duet firmware
                    M111 S0                             ; Debug off
                    M550 PMyCoreXY				        ; Machine name (can be anything you like)
                    M551 Preprap                        ; Machine password (used for FTP connections)
                    M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
                    ;*** Adjust the IP address and gateway in the following 2 lines to suit your network
                    M552 S1 P0.0.0.0						; IP address (0 = use DHCP)
                    M554 P192.168.1.1                   ; Gateway
                    M553 P255.255.255.0                 ; Netmask
                    M555 P1                             ; Set output to look like Marlin
                    M575 P1 B57600 S1					; Comms parameters for PanelDue
                    ; Machine configuration
                    M569 P0 S0							; Drive 0 goes forwards (change to S0 to reverse it)
                    M569 P1 S1							; Drive 1 goes forwards
                    M569 P2 S0							; Drive 2 goes forwards
                    M569 P3 S1							; Drive 3 goes forwards
                    M569 P4 S1							; Drive 4 goes forwards
                    ; If you use an endstop switch for Z homing, change Z0 to Z1 in the following line, and see also M558 command later in this file
                    M574 X1 Y1 Z0 S1					; set endstop configuration (X and Y and endstops only, at low end, active high)
                    M667 S1								; set CoreXY mode
                    M92 X80 Y80 Z800					; Set axis steps/mm
                    M92 E402:402						; Set extruder steps/mm
                    M906 X2000 Y2000 Z2000 E800           ; Set motor currents (mA)
                    M201 X600 Y500 Z5 E1000            ; Accelerations (mm/s^2)
                    M203 X15000 Y15000 Z500 E3600       ; Maximum speeds (mm/min)
                    M566 X600 Y600 Z30 E20              ; Maximum jerk speeds mm/minute
                    M208 X450 Y500 Z1083					; set axis maxima (adjust to suit your machine)
                    M208 X-8 Y0 Z-0.5 S1				; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
                    G21                                 ; Work in millimetres
                    G90                                 ; Send absolute coordinates...
                    M83                                 ; ...but relative extruder moves
                    ; Z probe
                    M558 P1 X0 Y0 Z1                    ; Analog Z probe, also used for homing the Z axis
                    G31 Z1.20 P500                      ; Set the probe height and threshold (put your own values here)
                    ; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
                    ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
                    M557 P0 X60 Y0                      ; Four...
                    M557 P1 X60 Y165                    ; ...probe points...
                    M557 P2 X222 Y165                   ; ...for bed...
                    M557 P3 X222 Y0                     ; ...levelling
                    ;M557 P4 X141 Y82.5                 ; 5th probe point for levelling
                    ; Thermistors and heaters
                    ;*** If you have a Duet board with 1K thermistor series resistors, change R4700 to R1000 to the following M305 commands
                    ; You can also use S and B parameters to define the parameters of the thermistors you are using
                    M305 P0 R4700 H0 L0					; Put your own H and/or L values here to set the bed thermistor ADC correction
                    M305 P1 R4700 H0 L0					; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
                    M305 P2 R4700 H0 L0					; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
                    M301 H1 P10 I0.10 D100 T0.50 S1.0	; PID settings for extruder 0
                    M301 H2 P10 I0.10 D100 T0.50 S1.0	; PID settings for extruder 1
                    M570 S120							; Increase to allow extra heating time if needed
                    ; Tool definition
                    M563 P0 D0 H1 F0                  ; Define tool 0
                    G10 P0 S0 R0                        ; Set tool 0 operating and standby temperatures
                    ;*** If you have a dual-nozzle build, un-comment the following 3 lines
                    M563 P1 D1 H2 F0                     ; Define tool 1
                    G10 P1 S0 R0                       ; Set tool 1 operating and standby temperatures
                    ;*** If you are using axis compensation, put the figures in the following command
                    M556 S78 X0 Y0 Z0                   ; Axis compensation here
                    T0									; select first hot end
                    ; Fan Configuration
                    M106 P0 H-1 B0.2
                    M106 P1 H-1	B0.2
                    M106 P2 H-1	B0.2
                      number40fan
                      Can you confirm that you are getting 12 volts and a ground out of the connection that you are using?
                        tommertens
                        I would have done but upon attempting to check with the multimeter I slipped and shorted something out. Board is dead.
                          I'm sorry to hear of your misfortune. Is the board completely dead, or just the fan outputs?
