Latest PanelDue Hardware?
930
    raykholo
    I'd like to build a PanelDue, my LCD arrived today. I see in David's blog that there is now a "Version 3" referenced which has a SAM4, however I only see a version 2.0 pcb in the dc42/paneldue github repo. Is there a new PCB design for v3, or did the SAM4 drop right in to the same pcb v2.0?
    Thank you!
      The PCB did change and I need to update github.
        raykholo
        Thank you David, I am looking forward to it so I can order the pcb and components.
          gnafin
          Will the Ver 3 still fit into this case? https://www.thingiverse.com/thing:2495311
            Version 3 should fit any enclosure that was designed to accommodate version 2.
              gnafin
              Thank you David.
                raykholo
                Thanks David for getting the files up so quickly.
                I have a question regarding the Crystal XT1: there are different load capacitance options, namely 12pf and 18pf, can you suggest if a particular one is needed?
                I am down to these options: https://www.arrow.com/en/products/search?prodline=Crystals&selectedType=plNames&filters=Standard+Frequency:12;Pin+Count:2;Standard+Package+Name:SMD;&sortBy=calculatedPrice&sortDirection=asc
                Thanks for your time.
                  Check the SAM4S datasheet, I recall that it is quite particular in the range of load capacitance and ESR that it likes.
                  1 out of 8
