    Hidden Z-offset Duet3
    Using Duet Controllers
    747
    • FrankVundefined
      FrankV @fcwilt
      @fcwilt
      Dear Frederick,
      I think I found the problem. I did several test's.
      At room temperature my z-offset = 0.95
      My bed at 90 degrees celcius my z-offset = 1.27
      My hotend at 250 degrees celcius my z-offset = 1.87
      The pinda is just behind the hotend so the temperature is influencing the pinda probe up to 1 mm.
      The other thing is even at room temp when I do automatic bed level the same point is getting a compensation of -0.1.
      So my conclusion is. Temperature is influencing the probe to much. I tried the temp sensor of the pinda to get corrected for temp. But I don't find how it's calculated and how that algorithm works and if it solves my problem. I ordered a super pinda. Hope it solves the temp issue. I got a bl touch laying around so maybe give that one a try. I never imagine temp is influencing almost 1 mm.
      • fcwiltundefined
        fcwilt @FrankV
        @frankv
        Interesting about the change in readings.
        I use an inductive probe on one of my printers but I never thought to check for temperature sensitivity.
        I did mount the hotend cooling fan so it sucks air past the inductive probe on the way to the hotend. Perhaps that is why I never encountered any problems.
        But I also create the height map with bed/hotend at working temps.
        FrankVundefined 2 Replies Last reply Reply Quote 0
        • FrankVundefined
          FrankV @fcwilt
          @fcwilt
          Frederick i think i add these lines. I have to check the C factor with the probe temp sensor. First without compenation and then with compensation and see what the result is.
          ;M308 S2 P"temp2" A"Pinda" Y"thermistor" T100000 B3950 ; temperature of PINDA2
          ;G31 P500 X0 Y-24 Z0.95 S21 H2 C0.02 ; C' (temperature coefficient of Z parameter in mm/°C, default zero
          • FrankVundefined
            FrankV @fcwilt
            @fcwilt
            Frederick,
            This is the graph produced by the Z- probe thermistor and my measurements of the Z offset by G30 S-1 at specific temperatures. So 50 degrees is 1mm extra z-offset this makes the C in the G31 temperature coefficient of Z parameter in mm/°C 0.02 although it's not lineair.
            I am adding in config.g:
            Tried this but it's not leading to higher the trigger distance when the probe is 50 degrees hotter. So this is not working. My superpinda just arrived wich seems to be temperature resistent. Let's try because this is not leading to consistent z-offset in my case.
            I changed in config.g the C to T because of Firmware 3.3 in my machine and now it's working:
            G31 P500 X0 Y-24 Z0.95 S21 H2 T0.02 ; T' (temperature coefficient of Z parameter in mm/°C, default zero
            Still going to test the superpinda, see if it works better without compensation.
            • fcwiltundefined
              fcwilt @FrankV
              @frankv
              Interesting.
              Glad to hear you got the settings sorted for the probe.
              FrankVundefined 1 Reply Last reply Reply Quote 0
              • FrankVundefined
                FrankV @fcwilt
                @fcwilt Frederick thanks for your help.
                • fcwiltundefined
                  fcwilt @FrankV
                  @frankv said in Hidden Z-offset Duet3:
                  Always glad to do what I can.
                  • FrankVundefined
                    FrankV @FrankV
                    A little status update from my part. Today I installed the superPinda probe. This probe has no need for temperature compensation like the Pinda V2. It works great and keeps logic more simple to calculate the Z-offsets. Also there is less difference when I probe again and again. So I can advise this superPinda also sold as upgrade from Prusa. You can buy it better from them because it's much cheaper as the orginal manufacturer price from Pepperl-fuchs (superPINDA)
                    Inductive sensor NBN2,5-8GM35-E1L-Y. I attached the datasheet if anyone is interested. It's rated till 80degrees celcius. I heated it till 110 with no deviation.
                    Brown is 5V
                    Blue is GND
                    Black is signal
                    An easy drop in to one of the endstop io's when you remove the wings from the connector.
                    SuperPrinda-datasheet_70134664_eng.pdf
                    In noticed even deviation of 1.04 mm at 80 degrees celcius.
                    • fcwiltundefined
                      fcwilt @FrankV
                      @frankv
                      You might find this site of interest. They have a large selection of good quality inductive sensors. For example they list 154 8mm diameter devices.
                      If you ever need a sensor with a greater sensing distance or faster switching speed you can likely find one to suit your needs.
                      Inductive Sensors
                      FrankVundefined 1 Reply Last reply Reply Quote 2
                      • FrankVundefined
                        FrankV @fcwilt
                        @fcwilt Frederick, thank you great site.
                        • FrankVundefined FrankV referenced this topic
